RHS 225 For a C5 Z06
My questions are:
1.-what head gasket should i use ?
2.-what valves and part number should i use?
3.-do i need to change my spring locators because i recently bought the BTR dual springs .660 lift
4.-do i need to flycut using a Torquer V2 cam?
5.-are this heads the same as Dart 225´s?
this is the link of the heads
http://www.ebay.com/itm/381147607954?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thank you very much for your help ,ill appreciate any help .
I didn't have to flycut, used a stock GM MLS head gaskets and I believe the RHS heads are Dart castings. Mine came with SS intake/exhaust valves(Rev IIRC)
If I was freshening them up...Id probably go with turned down LS3 intake valves to drop some weight in the valve train. 2.05 solid stem isn't a lightweight, although mines taken many 6800 rpm bashings pretty well so far.
do you need spring locators for your heads?thanks!
My car made 467rwhp/427rwtq one day and 457rwhp/415rwtq the next on a dynojet. Not setting the world on fire but for a budget un-ported set up...i feel like its where it should be.
Rips from 3500-6800rpm. RHS 225's werent my first, second or third choice as they arent widely used and not a lot of info out there...but got a smokin deal on the whole HCI set up. Nothing but good things to say so far...good luck w/ the set up
intake
http://www.ebay.com/itm/Chevy-GM-LS1-FERREA-6000-Stainless-Intake-Valves-2-05-4-900-set-8-/190797445645?pt=Race_Car_Parts&hash=item2c6c69fa0d&vxp=mtr
http://www.ebay.com/itm/MANLEY-RACE-FLO-RACE-MASTER-EXHAUST-VALVES-LS1-LS2-LS6-HEAD-1-600-/290882906288?pt=Race_Car_Parts&hash=item43b9f8e8b0&vxp=mtr
for the exhaust
thanks!
http://www.ebay.com/itm/Engine-Pro-Black-Nitro-Exh-Valves-LS1-1-600-Head-Diameter-Set-of-8-/231498520815?pt=Motors_Car_Truck_Parts_Accessories&hash=item35e66318ef&vxp=mtr
thanks!
