Need help for sleeper build!
Old Feb 11, 2015 | 10:47 PM
SaLS1's Avatar
Default Need help for sleeper build!
So i have a stock 02 z28. I wanna put on ported ls6 heads, converter, 373 gears, and a cam. The thing is its gonna be a sleeper. I wanna know if anyone else is running a cam with stock exhaust and manifolds. And what would be the best sleeper cam. I was thinking just throughing a zo6 cam in it.
Old Feb 11, 2015 | 11:06 PM
JakeFusion's Avatar
Super Hulk Smash
I'd do something like 217/232 .605/.575 117+3 LSA... you can use the LSL/XE lobes for it. That's similar to what Thunder used to use in their Cheatr cams that used stock manifolds.
One other thing you could do is run LS7 manifolds, and then put a hidden nitrous setup on there... that'd be a sleeper.
Old Feb 11, 2015 | 11:37 PM
SaLS1's Avatar
Yeah i was gonna run a dry kit. Run it to the air box and cover it with some black plastic hoses.
Old Feb 11, 2015 | 11:49 PM
JakeFusion's Avatar
Super Hulk Smash
I wouldn't do that. I'd run a money maker kit. Completely hidden. And it's a wet kit. Much safer with much larger amounts of spray...
Old Feb 12, 2015 | 03:49 AM
SSEUL8R's Avatar
I first got into the LS game in 2003 when a buddy of mine put ET streets, 3.73 gears and a 150 shot on a bone stock 99 z28 a4 and ran 11.20. That thing surprised a lot of people. Just food for thought if you want a sleeper. You can hide a wet kit very easily.
Old Feb 12, 2015 | 06:29 AM
Tuskyz28's Avatar
I'm just liking the approach you taking....... just awesome. I bet that cam Jake posted above doesn't have no lope at idle which is keeping things sleeper status!!
Old Feb 12, 2015 | 09:20 AM
SaLS1's Avatar
Yea my dad had a 01. With heads,cam,exhaust,turbo400,spray,full supension, and some other goodies. It runs good, he just wont pop the hood 😉
Old Feb 12, 2015 | 09:23 AM
SaLS1's Avatar
plus i wanted to keep the stock exhaust to keep a cam even more quiet. Im going to suprise most of the guys around town thinking there 5.0 mustangs are fast 😊
Old Feb 12, 2015 | 09:50 AM
ragtopz28's Avatar
Ok, I am SURE I'm going to get flamed for this....(I am somewhat old school).......A reverse split cam theory is they make up for poor intake capacity and exhaust expulsion. I had one of the old TR230/224 and it made crazy low end torque (which IMHO is what is needed for "street play").
OK guys, let the flaming begin
Old Feb 12, 2015 | 09:54 AM
redtan's Avatar
A reverse split cam theory is they make up for poor intake capacity and exhaust expulsion. I had one of the old TR230/224 and it made crazy low end torque (which IMHO is what is needed for "street play".
That might work when you have a shitty intake and well flowing long tube exhaust headers, but he's on stock manifolds which are crap. It be more beneficial to help out the exhaust moreso than the intake at this point. He could do an LS6 intake and have great intake flow but the limiting factor is still the lack of headers.
For ultimate sleeper factor you want a short intake duration cam with biiiig lift and a long exhaust duration with low lift plus wide LSA with lots of advance ground in.
Old Feb 12, 2015 | 10:03 AM
ragtopz28's Avatar
^^You are correct, I had by theory facts messed up. He has a LS6 intake (02) and poor exhaust....So how about 218/230 ish, .600 and 115+4 ??
Old Feb 12, 2015 | 10:08 AM
redtan's Avatar
Very similar to what Jake mentioned and probably his best bet. Would be torque city from the early IVC and advance but also carry the power up top very well due to the long exhaust duration and wide LSA. With the heads he plans on putting on this could be a very well running car.
Oh and it will idle like stock with -4* of overlap and a tune. Most people would be very hard pressed to even know that he has a cam in there from listening to his exhaust.
Old Feb 12, 2015 | 10:18 AM
SaLS1's Avatar
^^Agreed. Also the money maker kits are almost impossible to find. So can someone help me out with a link. And im actually gonna do what jake said and put on some ls7 manifolds. Im putting this sleeper together to get money to start building my lsx twin turbo that will go into it later in life. Once everyone realizes my car isnt stock😃
Old Feb 12, 2015 | 10:21 AM
JakeFusion's Avatar
Super Hulk Smash
The cam I posted will make plenty of torque and carry the power, even with stock manifolds. I still think the LS7 manifolds are a nice upgrade. Worth probably 10-15rwhp.
Add a 150 shot to it, a decent converter... maybe SS3200 or SS3600 and the 3.73s, drag radials... you'd have a very fast car that sounds bone stock.
Talk to Nitrous Outlet about their money maker kit.
I would go to either Tick or BTR and get a custom ground cam similar to what I posted. Add the BTR Trunion upgrade, Ported Oil Pump, Hardened Pushrods, Katech C5R Timing Chain, BTR valve springs, and the gaskets.
Old Feb 12, 2015 | 10:36 AM
CGCBandit's Avatar
I ran a tr cheatr cam years ago on my 04 gto. With a 3200 stall and stock exhaust it made around 368rwhp iirc(long time ago). Car sounded bone stock and ran 11.80's-11.90's back in '05.
Old Feb 12, 2015 | 10:44 AM
JakeFusion's Avatar
Super Hulk Smash
And that's in a GTO. The F-Body will be even faster. Then add nitrous on top... yeah that'd be a fun car that would surprise a lot of people.
Old Feb 12, 2015 | 10:49 AM
SAPPER's Avatar
Almost what I did. My 02 had an A4, 2.73 gears, LT, ORY, Hooker catback, ported TB & MAF with a 150 shot and no tune what-so-ever. With DR's it ran 7.4's consistantly. Without any stall I had to hit the nitrous at about 40-50' out.
Then I demodded it and traded it in on a truck.
Not a killer car but definitely ran strong for being in the 2003-2004 era.
My License plate even read SLEPRZ. It's on my dually now. LOL
Old Feb 12, 2015 | 12:40 PM
redtan's Avatar
Do LS7 manifolds even fit an fbody? Aren't they block hugger style compared to stock which is offset to a side? I know they don't fit GTOs for the very same reason.
And even if they did fit, won't exactly be "sleeper" as most people will easily be able to tell those aren't stock.
Old Feb 12, 2015 | 12:58 PM
SaLS1's Avatar
thats a good question. Idk if the ls7 manifolds would fit in the fbody. But if someone would complain about the 10 extra horsepower. Im going to laugh at them. Still would have full exhaust. Plus i could talk my way outta that anyways.
Old Feb 12, 2015 | 01:07 PM
JakeFusion's Avatar
Super Hulk Smash
I don't know. I thought they would fit. And they still look pretty stock.
