Drilling out ARP crank bolt?
Wow....I know it's hindsight, but geeze, the proper tool isnt that expensive and being the pully is press fit, your not going to be able to smack it on. Too many people here have learned the hard way pressing it on with the bolt. 99% of the time ends with stripped threads....
Youre screwed. The ARP bolt is a hard high strength alloy. You will need one expensive drill bit to drill it out. Your best best will be to wrench it out. The threads in the crank are toast.
A bad situation to be in....this is going to be expensive for you.
http://www.summitracing.com/parts/sum-900135
Btw unlike the hawk tool, the summit rods looks long enough to cover the longer ls7
The real thing has a stronger rod and uses a bearing....like I said in another post, going cheap will likely cost you more money later when you damage something,. That home made tool is like using a longer bolt.
The real tool has a wrenching point to keep the rod from turning while another wrenching point with the bearing to draw it on....don't go cheap. This is a sure way to alleviate any possibility of screwing something up.
Also for anyone reading you can heat the pulley at 250 degrees in the oven for 30 minute, grab it with oven mits and it will literally fall onto the crank then just torque the bolt down. For the bits try fastenal maybe?
So, original question - anyone know where to get some decent/long drill bits?
I will pass on putting my $500 ATI in the oven....bad thing to do with something that has rubber in it. Why are folks so frugal? Geeze you're wasting money trying to save money when you risk damaging parts.
Also if you have installed the ati you should also know that you can install just the hub and ac pulley by themselves first, meaning if you were that paranoid you dont even have to get the rubber piece hot. Just heat the hub up and put it on with the ac pulley, let it cool then do the front pulley. I used the install tool many times and its worked great however heat takes any of those variables out of the equation because it slips right on and you feel it bottom out.
Wasting money is buying a 50 dollar install tool that looks reall neat when you can make one for less than 10 bucks that is just as safe and works every time. Or you can follow what the manufacturers recommend and heat it for free.
Using the proper tool it's not bad advice.....it's smarter based on all these " oops " post
Slightly different, but I don't endorse the hawk tool anyways. I praised the Summit house brand which in my opinion is better.
FWIW, I don't need to be concerned on what you of other folks use. I just suggest and advise to use the tool I know works and no risk of damage. We all need to make that decision based on cost and acceptable risk.
Same thing on the stud it doesnt move once its in the hole. Again then how do you install head studs? You dont hold the stud, just torque it down. Its the EXACT same principle except a cylinder head puts more stress on the std since the head is clamping to the block. The balancer actually gives since its being pressed on, ie less stress. Here are ARP's instructions for their studs, no meniton of holding anything....http://arpinstructions.com/instructions/234-4317.pdf
And to the OP, if you can't drill out the broken bolt you might call some machine shops and see if they can EDM it out. (Electric Discharge Machining) I've read here where it can be done without pulling the engine.
