Recommended Viscosity Oil?
Thanks
5W-30 is just about perfect for most modern engines.
Far as weight you will have folks who don't understand viscosity tell you things like 5w-30 was GM spec so use that. Reality is OEMs have a lot of concerns that are NOT about engine life, and that the "30" part is a range, one 0w-30 is thicker at operating temp than another 10w-30 and a year later as formulas change the 10w-30 might endup thicker.
If you want to worry about viscosity alone any 0w, 10w, 5w-30 or even 40 is going to do the job and picking between viscosities and brands beyond that is pretty much splitting hairs.
Someone wants to argue that please put up the UOA results.
As a general rule of thumb, you want something thick enough and resistant to shearing at high loads that you might expect the engine to see and thin enough at cold startup that it will flow well in whatever temps the engine will see.
I personally run a 0w40 in my LS2 just because I tend to use it in really cold weather hence the first number, and also have heard and read that LS engines like slightly thicker oil especially older ones.
OEM oil recommendations are around fuel economy and not so much engine life. Most manufacturers could care less if an engine lives 100k or 200k as most likely the car will be long out of warranty by then. That's why you're starting to see oils as thin as 5w20 in mainstream cars. Alot of the hipo European cars require upwards of Xw50 or 60 oils for protection. Now obviously that depends also on the clearances built into the engine, but ultimate protection also has to do with it.
Lingenfelter said the same pretty much but said bearing clearance plays a roll too. Grrrrr... wish I could talk with the original builder on this.
I can't speak to how well these engines will hold up after 100k, as that's the oil they're designed around, but I know that fuel economy is a major factor. The harder it is to pump, the more fuel you use.
For hardcore car guys like us who like to have fun and drive our cars hard at the strip or track I don't think that type of oil will protect the engine enough.
What start up temperatures will be.
What normal operating temperatures will be.
What rpms the engine will see.
What engine loads will be.
I run 10-40 in the summer in all my vehicles and 5-30 in the winter, I live in the Midwest and we see extreme swings from one season to the next. 100+ in the summer and well below 0 in the winter.
When I raced (circle track) I ran 20-50 with a zinc additive because the motor saw sustained high rpms and loads lap after lap.
I have an LS3 based 427 with slightly large bearing clearances and I was running a 5W30 oil and the oil pressure was to low for me. I changed to a 10W40 and things are much better. I am considering a 5W50 synthetic or so when the motor is broken in. I also live in Southern California so the weather does not get that cold.
