head bolt pop help!
Old Mar 11, 2015 | 01:13 AM
JROWS6's Avatar
Default head bolt pop help!
just how it says, i was putting back my heads onto my ls1 block and as i was putting the first bolt back in not even half way, suddenly a pop noise, took the bolt off, take the head off to check and i find a little chip off the block, my guess is that there was water in the cylinder bolt hole, im guessing bolt sealed up as i was torquing down the bolt created pressure and the block gave out, i will attach some pictures of what im talking about, i inserted a copper wire so you can see were the piece came out of. Now my question is has this happened to anybody else and have they been able to use the block again and did it run fine?? would be a good idea to weld that hole back up assemble everything back up??? What are your thoughts???
Old Mar 11, 2015 | 06:34 AM
vettenuts's Avatar
You really need to inspect the block good for cracks. You may have dodged a bullet but when this is done the block is typically cracked and unusable.
Old Mar 11, 2015 | 07:53 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Originally Posted by JROWS6
.....i inserted a copper wire so you can see were the piece came out of.
Quite sorry, the block is junk.There's no repairing that.
Old Mar 11, 2015 | 08:20 AM
KCS's Avatar
KCS
Moderator
I would junk the block personally, however, I have seen a couple guys on here who have said they did the same thing and ran it anyways.
Old Mar 11, 2015 | 09:15 AM
Jake99's Avatar
I did that to mine, I put some thread sealent on the bolt and tightened her down. Ran it 2 years at 600hp and never had a problem. Guy I sold it too is still running it as far as I know.
Old Mar 11, 2015 | 08:38 PM
S10xGN's Avatar
I'm curious as to why a block is considered "junk" when a headbolt pops internally, but it's OK to run when one pops externally? As far as I see it, doping the new bolt will work no matter which bolt hole is now "bottomless"...
Old Mar 11, 2015 | 08:50 PM
Paul Bell's Avatar
I consider the block's strength compromised.
Old Mar 11, 2015 | 09:25 PM
S10xGN's Avatar
Paul, you're a pretty sharp guy. I'm just not seeing what difference one headbolt breach makes over another. There are ten 11mm bolts, are you saying these ten holes have varying degrees of clamping strength? That the holes on the inside of the block are somehow more critical than those to the outside?
Old Mar 11, 2015 | 09:39 PM
Paul Bell's Avatar
You might be able to get away using this block. I wouldn't attempt it. If you're building an engine, get it right the first time.
Old Mar 17, 2015 | 02:55 PM
JROWS6's Avatar
thanks for advice, il let you guys know how this works out.
Old Mar 31, 2015 | 02:14 PM
JROWS6's Avatar
After all i went ahead and used the same block added some sealant to the bolt and tightened everything up so far been driving it for a week and no single problem yet....
