Head Gasket or Cracked Head ?
Cracks or blown gaskets, is this a common problem.
I was pushing a crazy amount of water our of the RAD cap on the dyno during WOT with a brand new engine. I reused a set of CNC'd 317 heads from my previous engine.
I blew out the #7 cylinder on the next run after dialing it back a little bit.
During engine teardown, I later found a pin hole leak/crack in the head casting right were they CNC'd the runners. (Machine shop confirmed with Vac test) I believe it was just cut too thin and caused this area of the runner to crack, pulling water into the combustion chamber.
I also noticed water in the tail pipe, confirming my suspicions.
Just do all of the necessary checks before running that engine any more. Better safe than sorry IMO, even though it costs a few bucks to do this.
Drained the catch cans, nothing in there to my surprise. How could a steam cloud come out of the exhaust when I started it up ??? A crack in an intake port? Wow, That almost makes sense. Probably time to pull the heads, it's sure not going to fix itself.
