So I did the high performance sewing machine mod...
1. I put in a TR 224, with new springs and pushrods. Where is a good spot to set the rev limiter at?
2. Does anyone know of a good place not too far from upstate NY (within 5 hours) that can do a tune on it? It isn't bad now, just looking to get the most out of it.
3. Do the roller rockers, such as Harland Sharp's, quiet the valvetrain down a lot, a little, or not at all. I wasn't expecting it to be quite that loud up front, but hey, it is well worth the ride.
Thanks in advance and as soon as I can get to the track I'll post some times.
Congrats on the cam, these cars really wake up with them!
I wasn't thinking of going with 1.8's but I was seriously considering some HS 1.7's. I haven't seen anything bad said about them yet or has my head been in a hole for too long?
I don't quite agree with you on that. Harland Sharp rockers are pimp. They do quiet the valvetrain some and best of all they prevent side twisting of the rockers which give you a more stable geometry (Good to have when you rev till 6800)
They are so "beautiful" most poeple would like to have clear VCs to add to the show.
So far the only "problem" encountered with them is that they do slightly hit the corners of some 5.3 castings, but no major issue, nothing a little corner grinding won't fix.
If the rocker is too heavy, wouldn't that put more strain on the valve train, in return rob you of some HP?
As for the rockers, I was under the impression that a switch to 1.7 rollers would help with the noise also. I am not expecting gains, just a little less noise. Does anyone else have their .02 they want to throw in? I agree there are better places to throw money into (heads, rearend, clutch) but I would like to maximize what I have first before I go to the next level. By the way, in addition to the mods in my sig, I also have a ported throttle and gears, so realistically my next step is a set of Nittos and a clutch.
thats just Verbs.....he can't get anything right
as Orange Peel said, the Yella Terras a heavier rocker and as such if your valve springs are not strong enough, they will cause valve float (that and the fact that Verb's engine was about to come apart where the reasons he lost the HP
).I personally never liked them. They cost $500 and are still not adjustable. If your going to spend that much just go for something like the Comp Pro Mags or something.
Far superior to stock.(this week here was another post on a needle bearing in the oil pan)
Yeah I don't like them for the fact they are soooooo expensive, money best spent elsewhere
