help! SES and smoke out the pipes
The next day I go to take it to synergy motorsports to get it looked at but after driving the car for like 3 mins the SES light started FLASHING!!!!! So I turned around and went home. The light only flashed for a second then went back to steady on.
I was going to have it towed to the shop but the dude at AAA said it would cost me like $200!!! Does anyone have any ideas??? Its been really windy but from what i can tell the smoke looks greyish. I know its white blue or black but i just cant tell. All I know is I need HELP!!!!!!!!!!!!!!!
Thanks a lot guys
-Ryan
Like SSean said, get the code scanned. Autozone will do it for free.
Have you bolted anything on recently? Have you detailed the motor lately?
But they are correct, a blinking SES light 'usually' indicates a loose / broken plug wire.
1) You can buy a basic obd2 scanner from just about any autoparts store. A basic scan tool will run you about $100... But, now would be a good time for you plop down the money for Autotap or EFILive. Either of these two will let scan the car and reset the light for you. Both have plenty of other cool features. I have both and prefer EFILive. Your looking at $200 - $500 depending on the software package(s) you choose.
2) You can tow the car to the nearest scanner.
If you continue to drive the car with the blinking SES and it turns out to be a missfire - you should consider replacing your primary o2 sensors and cats. A healthy dose of raw fuel will ruin these real fast.
Plugs
Plug wires
Coil pack
These are also listed in cheapest to most expensive
Usually this is caused by a bad plug or plug wire. Coil packs can go bad, but with individual packs, it should out live the plugs & wires.
