Cam Or Headers?
Old Jun 2, 2004 | 12:20 PM
Casperws6's Avatar
Default Cam Or Headers?
I'm On A Budget So I Want To Know Whether A Cam Or Headers Will Give Me More Power? I Know People Are Going To Say I'm Going To Need Both To Get The Most Power But Which Should I Buy First? I Plan To Go With Lt's If I Do Get The Headers. Any Advice? Thanks
Old Jun 2, 2004 | 12:22 PM
WS6Cutie's Avatar
longtubes THEN cam
Old Jun 2, 2004 | 12:51 PM
WAHUSKER's Avatar
I agree with Cutie, get the headers first. For sure long tubes!
Old Jun 2, 2004 | 12:59 PM
HumpinSS's Avatar
CAM!!!!!!!!!!!!!!!!!!!!!!!! The cam will net more gains than the headers and when you do get the headers it will open it up even more. Not to mention the lope and everything else that comes along with the cam
Old Jun 2, 2004 | 01:11 PM
Tranzor's Avatar
headers definitely... a cam will choke on the stock manifolds and you won't get near the output possible on an aftermarket cam if you don't get the headers first.
It's a good rule of thumb to start on the outside (bolt-ons, drivetrain, suspension, etc) then work inward (cam, heads, etc).
Old Jun 2, 2004 | 01:15 PM
frey51's Avatar
again I must suggest headers first. If you think about it, even if you get the cam first you will have to tune again once you get the headers because the flow will change. At least that is how I see it. So it might cost you more to go cam first.
Old Jun 2, 2004 | 01:21 PM
BlackCamaroSS02's Avatar
i say get the headers first
Old Jun 2, 2004 | 01:38 PM
Blue Hawk's Avatar
Headers first!
If you're on a budget, don't forget that with the cam, you will also need new valvesprings, retainers and a good tuning. All that stuff add some $$$. And like frey51 said, you'll have to tune again if you do the cam first and add headers later.
Eric D.
99 Firehawk M6
Old Jun 2, 2004 | 01:55 PM
OWENMUSTANG's Avatar
headers....
don't need to pull v/c's,front cvr,chg valve springs,timing chain
won't have a cork in the exhaust (manifolds)
i guess you could do the cam 1st, but you will be leaving HP on the table
Old Jun 2, 2004 | 02:22 PM
NHRATA01's Avatar
I got the cam first only because it was on GP at the time for 600 bucks for the package. Anyways the car made plenty of power and pulled strong to 6600. Dyno'd at 367/353 UNCORRECTED (don't ask). That was for a little T1 though (.559/.559 221/221 112). For the bigger cams, I think exhaust breathing would be more of an issue through the stock manifolds. But believe it or not, those 2000+ manifolds do flow pretty decently.
Old Jun 2, 2004 | 04:24 PM
jrp's Avatar
jrp
SN95 Director
headers. check the guide in the external forum.
Old Jun 2, 2004 | 04:29 PM
PewterSS01's Avatar
I would have to agree with headers first. It would be great to get them both at the same time and do everything all at once, but that never happens.
Old Jun 2, 2004 | 04:30 PM
Derek98z's Avatar
Depends on the size of cam you want really. A buddy of mine has a WS6 with a T1 and stock manifolds churning out 375 rwhp. The most HP I have EVER seen from headers and a stock cam car was 358.
Old Jun 2, 2004 | 04:33 PM
01_SuperSlow's Avatar
Headers first definetely
Old Jun 2, 2004 | 04:39 PM
Derek98z's Avatar
forgot to throw this in. If you are on a budget (as I am) buy used parts. There are plenty of stand up guys here selling great used parts very cheap. My cam and headers are both used. Maybe purchase first the product you find the best deal on at the time.
BTW (since I say cam) the cam might be slightly choked from the stock manifolds, but nearly as much as people might tell you. You can still expect significant gains from the cam and then huge gains when you throw the headers on and the cam can breathe.
Old Jun 2, 2004 | 04:43 PM
2001CamaroGuy's Avatar
the cam will give you more HP but I would still do headers first.....
the problem with doing the cam first is either:
a) if its small enough to work with the factory heads and exhaust manifolds, it will really suck when you upgrade the other stuff
b) if its big enough to work with the ported heads and headers, it will be really choked up on the stock stuff
Hooker LTs and a Y-pipe are about $600.......then start saving for your heads AND cam (do both......60+% of the work of one is needed when you do the other)
Old Jun 2, 2004 | 05:11 PM
gabeg94z's Avatar
Default cam prob on lt1?
i just had a rebuild and went ahead and put a cam but the car runs like crap and i cant find what the prod is . it runs real slugish and has a hard take off but then it just makes noise and goes nowhere. thanks
Old Jun 2, 2004 | 05:19 PM
gabeg94z's Avatar
is that true that the cam cant breath?
did you tune it?
Old Jun 2, 2004 | 05:23 PM
Derek98z's Avatar
Were you trying to start a new thread?
