"243" Vette Cyl Head ID???
Did all Vette's come with the light weight valves in 04'??
Thanks in advance, I have sort of short notice on these...and I suck at the search...
Thanks man...that's kinda' what I had gathered from my search...
I don't think I'll be able to pull a valve...a local yard has them at a pretty reasonable price...I think I'll just roll the dice and see...
Those are the only vehicles that came with those "ls6" valves
Burken01, I saw you replied to this post where Ari G is selling a set for $300 ; still no takers. I don't understand why people would pay $250 for titanium retainers to save 5 grams but balk at $300 to save 25 grams ?
Also I've seen ls6 heads with orangish springs..
You have to weigh the valves, anybody can change springs as well
I never really gave it much thought, but when I used a LS6/Z06 "5308" cam in my 5.3 build...I needed longer pushrods because of the reduced base circle...The Z06 used stock length 7.400" pushrods...so the valves have to be longer to make up the difference for the .050" reduced base circle...correct???
Here's what I'd do...take a valve spring compressor and tell them that you need to check the tightness of the valve guides. Make up a story about how you once bought a set that were from an oil neglected engine and the repair costs made them junk. Pop out one In. and an Ex....you will feel the difference immediately. Obviously they need the yellow springs or else for sure they have the standard valves.
