5.3 acting like a 4cylinder
. Please help me Ive spent atleast 7,000.00 building this truck and doing it the right way and then this happens. I have two kids and a wife to support and im running low on funds any help would be greatly appreciated and prolly keep me from getting a divorce lol. Cam sensor wiring does not like being by the other wiring on the harness, so try moving it out by itself a bit and see if that changes anything for you.
Dumbest fix I ever saw and we verified over and over again the wiring was good,etc,etc.
Thought about it for a bit after reading your reply.
Long story short, the way he ended up routing the harness in the area caused issues later.
Car was running on one bank only.
Went thru everything and it vanished after we separated parts of the harness.
It has never happened again once we did a little rerouting. Never found a reason, pierced wire, suspect area, nothing...
I'll give him a call t'row and ask which bank was running and which was not.
Here is some good info on the po 200 code injector circuit
https://ls1tech.com/forums/fueling-i...r-circuit.html
2003-2005 are interchangeable and the harness should be as well.
You can not flash an 03-05 operating system and use an 06-07 classic TB, Pedal, and Tac module or Vice Versa.
The main Coil pack connection on the valve covers is also a good place to look as it is easy to bend a pin there.
Regarding the old PCM, How do you know it was bad? was it burned?
You stated you had the replacement PCM was reflashed with your vin. Was it done with tuning software? Are you sure it has a V8 calibration in it.
Where are you located?
http://www.obd-codes.com/p2135
The P0101 could be a secondary condition to the Rep mode.
I would focus on the P2135 first.
.... Disconnect the battery and let it set for 10 minutes then reconnect.
Fire up engine and let it idle on its own for at least 10 minutes do not rev durring this time. The computer will adjust itself automatically. You can give some gas if need to get it started but slowly bring it down till it idles on it own. again it must idle on its own for 10 minutes from a cold start.
Other wise you need a scan tool with bi directional controls to do it properly.
