New Product Launch....Mamo Motorsports 235 cc
#42
Solid 110 grams
Hollow 89 grams
MMS 250 (2.165)
Solid is 114 grams
Hollow is 92 grams
Hollow is always the way to go....even with the MMS 220's. Better valve control equals more power and more reliability (valve bounce can cause p to v issues).....springs last longer as well controlling less mass over millions of cycles. And the power curves look sexy smooth.....no jagged BS if you get all the other details right (valvetrain related).
(And I answered these questions hours ahead of my typical schedule! )
i heard in this thread, or maybe another one how much tq is lost with the
vic jr and super vic intakes compared to say an llsxr or whatever it is...
would you say the endlebrock pro flow intake would be a better choice then the super vic??
i plan on getting a set of the mms235s for sure when im ready to upgrade heads.
Regarding the Eddy Pro Flow if you have room for that you should be running the FAST LSXRT which IMO is the best all around intake your going to bolt on a dual purpose street strip car.....problem is it wont fit very many applications but if your lucky enough to have one that will allow it to install, the LSXRT is the total package.....big torque and big power upstairs.
Hope this helps
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
#43
MMS 235 is a 2.100
No single plane will come close to the low midrange TQ of the FAST and even upstairs they kind of suck unless you have the room for a top mounted TB and no 90' elbow.
Hope this helps
-Tony
Hope this helps
-Tony
the endlebrock pro flow intake is alot cheaper then the fast.. i plan on going twin turbo down the line so spending more then i need to for the intake manifold is foolish in my eyes... eventually when i have a aftermarket block, and tons of good parts ill have my friend at the fab shop make me a sheet metal intake manifold..
i just wanted your opinion if i should pick the endlebrock pro flow over the endlebrock super vic?? your opinion MEANS ALOT in this world..
def going to get your heads.. cant beat them in any way or form!!
#46
From: Coast of San Mateo County Between Pacifica & HMB
MMS 235s Physically to Big to fit on Bore smaller then 4.0"
The MMS 220s will be killer on that 383.
(Ideal cam probably 231*-235* intake duration
Add 4*-6* on exhaust with LSA 114*+2*-3* ADV.)
Exhaust duration on your cam is just a hair big but will still be excellent
If you already have it and will have awesome low and mid range Throttle response with great street manners. Actually F body without true duals probably
Ideal.
Ideal.
#47
#48
Tony help this fellow out. https://ls1tech.com/forums/generatio...00hp-fwhp.html
I will chime in there later tonight time permitting
-Tony
__________________
#50
No need IMO.....with the AFR 3/4" deck and good hardware as long as your tune is close you can pretty much make 900 RWHP or so with good longevity. If your looking for more than that you should be in a square port head anyway (larger LS3 or LS7 port) and I would just use a TFS casting at that point to help my customer (they have six bolt options).
-Tony
-Tony
__________________
#52
The only thing still questionable is the intake valve size which may grow as much as .010 at the most. Im kind of killing myself trying to get this small valve small port head to 300 CFM just cause it would be awesome to advertise there versus 296 CFM.....LOL
Im in the mid 290's now....even there Im very happy with it but you know how it goes!
-Tony
__________________
#53
I've used Manley's 7mm (.274") intake valve to cheat-up limited stock car head applications, although admittedly I did not do pre and post flow testing..
I've also wondered what if any improvement could be had with a valve guide trailing wing....sorta like a pointed guide extension on the chamber side of the intake valve stem.
#55
Tony...
on your new 235 NFI's (4.00 bore minimum), if I understand you correctly these are similar to your regular 235's but with bigger exhaust diameter?
head............... ID .............. ED
235 reg.......... 2.100 ........ 1.600 yielding int/exh of 342/260 @ .650 lift
235 NFI......... 2.100 ........ ?.??? yielding int/exh of ???/??? @ .650 lift
Thanks in advanced
Thanks in advanced
#56
Tony...
Thanks in advanced
Thanks in advanced
#57
Tony...
Thanks in advanced
Thanks in advanced
Exhaust has a 1.630 valve....same flow at .200....up a few at .300....up 6 CFM at .400.....after that its about 8-10 better the rest of the way.
268 - 270 CFM at .650....272-273 CFM at .700
I will post all the numbers after I bench test the next couple of heads I have in the works but its the highest flowing exhaust port of any LS I have tested no matter the brand....the size runner.....the type of head (LS7....LS3.....whatever).
On my bench....an SBC head going more than 260 CFM doesn't happen very often. A few years back getting 250 CFM was a milestone and the heads that accomplished that made big power.
-Tony
PS....One of my "regular" MMS 235 customers who just swapped heads, rockers and lifters....used the same cam.....same engine....and reinstalled it in the same car picked up 4 MPH trap speed on his first track outing over his previous best which was accomplished with a set of ported OEM castings (its a 408 CID engine btw). Obviously better weather conditions and more time spent dialing in the new combo will only widen that gap even more but even his current gain is very significant. I believe he is going to post his results at some point but the change to the shape of the power curve was/is insane. The engine hadn't peaked at 6700 yet when the dyno operator shut down the pull (I hate that btw....don't know why so many shops do that)....it carried 98% of peak TQ for like 1000 RPM....it was retarded. He also reduced his ET and got into the 10's for the first time running a 10.93.....It's a 99' C5 and he still has an unported 92 FAST on there and a 2.5" exhaust.....there is so much more potential here its crazy.
__________________
#60
Tony,
Interesting data. On the 408 you referenced, I assume that's an NA setup?
Is it possible to have "too much" exhaust airflow? That seems like a silly question, but I would think if engines continued to need more and more than castings would be available that offer it. I recall from the deep crevices of my memory that 75-80% is the typical targeted number, but I don't know where that comes from... I'd appreciate more education in this area, particularly since it seems GM is now producing heads that are moving further away from that with the large intake flow numbers...
Thanx!
Thanx!
