Have you had the JOY of installing spiral locks?
Old Jun 3, 2004 | 09:54 PM
2001CamaroGuy's Avatar
Default Have you had the JOY of installing spiral locks?
If not then I hate you so very much ......
damn....seriously though I just got finished installing all of them in my pistons (3 hours!) and my fingers are in pain. Oh well....its one step closer to startup .
Does anyone make a tool or have any tricks for doing this in the future?
Old Jun 3, 2004 | 09:57 PM
427's Avatar
427
Chris,
you just get alot faster with practice... your fingers will still hurt!!
Kurt
Old Jun 3, 2004 | 10:11 PM
Jason99T/A's Avatar
I can shift faster than you.
Yep, as Kurt said, with a little practice, you can get them installed in well under an hour. But, your fingers will pay the price!
Jason
Old Jun 3, 2004 | 10:24 PM
Country Boy's Avatar
Senior Member
The first ones took forever, but I can do them all in about 30 mins now. They are a major PITA.. lol just fingers and a small flathead screwdriver.
Old Jun 4, 2004 | 12:15 AM
mbaskett's Avatar
been there done that. THese guys are all right though... You get faster, as you do them more, but no matter what, your fingers will still let you know they don't like them....
Now what'as REALLY fun is taking out double spiro-locks... That's some fun!
Old Jun 4, 2004 | 02:29 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default Spiro locks
Chris,
First thing to do is stretch them out a bit so you get a gap between the coils. Makes it a lot easier to get them started with a small screwdriver as was mentioned.
I don't use spiro locks if round wire clips are available. The round wire clip requires a chamfered wrist pin. One advantage is they are easier to install and remove without harming the pistons. Biggest advantage is the wrist pin actually forces them tighter into their groove instead of trying to force them out.
Steve Demirjian
Race Engine Development
Old Jun 4, 2004 | 10:15 AM
I guess I could have used those since the wrist pins are SBC. Is there anything else special that needs to be done to use round clips? I might go that route when I do my big block.
Something to know, how do I get the spiral locks out if for some reason I need to?
Old Jun 4, 2004 | 11:50 AM
Scalpel's Avatar
What are spiral locks? *ignorance speaks here*
Old Jun 4, 2004 | 11:58 AM
what? I'm talking about the little locks that hold the wrist pin in the pistons.....some places call them spiral locks and others call them spiro locks .....
Old Jun 4, 2004 | 12:19 PM
LS1TECH Sponsor
Default Lock rings
Chris,
You must specify round wire locks with your piston and pin order. I also order removal slots to make life easier if they need to be removed. In fact these slots can also be ordered for spiro locks.
Levi,
Spiro lock is a flat wound (two coils) pin retainer usually about .040" thick. You use two per side. The round wire clip is much better in my opinion. It is used on a lot of foreign engines (for years). Cosworth came out with them for racing back in the late seventies.
Steve
Old Jun 4, 2004 | 12:26 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
As stated, stretch them apart a bit (makes life much easier) in fact you can almost screw them in that way (small screwdriver helps out though).
Old Jun 4, 2004 | 12:28 PM
my diamond pistons only had one per side but they were twice the thickness of a standard lock.
Old Jun 5, 2004 | 01:41 AM
Time2Kill's Avatar
MASS seller approved
Ive done a set of spiro locks and double spiro locks on Diamond pistons. MAJOR PITA. I used a tiny needle nose plier and was able to grab one end and just wind it into the groove. Didnt take too long and my fingers thanked me
Old Jun 5, 2004 | 05:52 AM
DaveSchott's Avatar
You think they're hard to install ...wait til you have to take them out for the first time
Old Jun 5, 2004 | 08:22 AM
jamnut's Avatar
We started using spiral locks on Harleys years ago, man I've always hated them. Then S&S started using teflon buttons that go on each side of your wrist pin. Those things are great, you just slide the wrist pin in the piston, put a teflon button on each side and put the whole thing in the bore, the bore size holds the buttons in & centers the pin in the piston. Why can't we use these in LS1's?
Old Jun 5, 2004 | 12:35 PM
Time2Kill's Avatar
Those teflon buttons are great, I've used them in R/C Car engines before. It just doesnt seem like they would be able to hold up for a very long time though.
Old Jun 5, 2004 | 03:07 PM
ktmrider's Avatar
Interesting stuff. I have to install some very soon and the info is a big help!
I agree about the wire locks and teflon, I have been doing motorcycle engines for many years and these products are great. Only down side is when one goes flying into the crankcase of a 2 stroke, time to get out the case splitter!
Old Jun 6, 2004 | 03:44 PM
Scalpel's Avatar
Thanks for the info!
