Mast head swap
Old Jul 20, 2015 | 09:54 AM
  #41
redbird555's Avatar
thats the fear I have always had with those stock bolts. every time i torqued them i would just cringe or have someone else do it while i watched lol. past couple motors I helped or did myself I used arp bolts.....Its worth the extra 100 bucks every day of the week, not only do you get a better reusable bolt but then you dont have to stretch it to the moon...
sucks to hear though im sorry, i have heard the top bolt holes dont even really do anything so just leave them out lol
Old Jul 20, 2015 | 10:41 AM
  #42
streetapproved's Avatar
With the power you were going to put down, I would have gone arp as well.
Old Jul 20, 2015 | 10:48 AM
  #43
KCS's Avatar
KCS
Moderator
I don't think that was the fault of the bolts. Looks like you pulled the aluminum out of the hole.
Old Jul 20, 2015 | 12:08 PM
  #44
Titokang's Avatar
Yeah can't really blame the bolts because the threads just pulled out clean, would've happened with any bolt. Need to see who has a time sert kit I can rent locally
Old Jul 20, 2015 | 12:13 PM
  #45
A.R. Shale Targa's Avatar
Nothing wrong with the stock bolts other than not being reusable. There's also some prep work to the ARP stuff to get repeatability that most overlook anyways. In this case I'm betting the tapping out cleaned but slightly weakened the threads in the block. IMO just merely hand snugging those with a 3/8" ratchet would be right around 20 ft/lbs. if the torque wrench being used starts at 15 or 20 it will not be as accurate as when it's in the middle 70% of its range and could also have contributed to this miss hap. Couple of heli coils should be fine but having to remove and replace all the bolts is what really sucks. Good luck man; hang in there and thanks for showing the common hardships as well as the great things to follow......
Old Jul 20, 2015 | 11:59 PM
  #46
Titokang's Avatar
Thanks for the kind words targa, I actually used a 3 inch 3/8 ratchet to snug up the bolts and my torque wrench starts at 10 ft pounds but having more leverage with the torque wrench I didn't even feel em pop or anything funky just kept spinning, my guess is it wasn't even 10 pounds of pressure. Just bummed out and don't wanna dump some money out of my next check on it yet to get it fixed. Debating going lq9 since here in south texas they're fairly inexpensive but not sure yet. Thanks guys, I'll keep my thread updated even though it's minuscule compared to most builds going on.
Old Jul 21, 2015 | 08:48 AM
  #47
Seriously ??? MAST heads are straight up baller and we need to know how they do on stock cubes; now if they suck, then you can have our permission to add cubes......LOL.
Old Jul 21, 2015 | 06:14 PM
  #48
CarlostheBarbarian's Avatar
Damn sorry about your luck...
Not to stir the cathedral vs square port thing...just curious why the small bores vs Mast's cathedral 215?
Im looking for a new set of heads and both Mast ls3 small bores and cathedral 215's look like a hell of an option.
Old Jul 21, 2015 | 07:31 PM
  #49
Titokang's Avatar
It's kind of a toss up, most good aftermarket heads are in the 2500 range, but for a cathedral a fast is pretty common so factory the price in on top of the heads. What I have in my setup is about the same price wise, but I wanted something I could grow with later on. Ls3 intakes are cheap and are known to work, been looking at a time sert kit for the m8 bolts and runs about 70 bucks I'll probably order one next week, keep you guys posted.
Old Jul 21, 2015 | 07:58 PM
  #50
64post's Avatar
You'll keep your "thread" updated? Lol. That's a good play on words. Like to see what that motor would do with those heads.
Old Jul 21, 2015 | 08:37 PM
  #51
Cool, makes sense. Good luck, looking forward to the results when you get it dialed in
Old Jul 23, 2015 | 12:23 AM
  #52
Titokang's Avatar
Anybody know where I can find some little plastic locks that go on the top of ls1 injectors? Looks like they sorta lock the top o ring in place. C clip type plastic if anyone knows what I'm talking about.
Old Jul 23, 2015 | 10:01 AM
  #53
Rise of the Phoenix's Avatar
I agree with you. I'm very anxious to see how these heads do on stock cubes. Others have purchased these heads, but sold them off before installing them. To my knowledge, this is going to be the first setup running them that's going to actually get completed. Good luck the rest of the way OP.
Old Jul 23, 2015 | 10:26 AM
  #54
scotty2000ss's Avatar
I was so close to buying these heads for my car. I had pretty much everything except for the heads but decided that it's time to sell my car.
When I was talking to Ed @ FTI he said - "We've made over 510 RWHP with those heads and the StreetSweeper so with the Hellion, it'll make even more."
Can't wait to see how this turns out.
Old Jul 23, 2015 | 12:26 PM
  #55
SCott5's Avatar
A few combos have been put together, just no one on tech. These heads and the mms heads are the top two on my list. Can't wait to see the progress
Old Jul 23, 2015 | 12:28 PM
  #56
Yeah, my statement was made regarding this site. I'm sure there are quite a few out there; just none that I have personally seen.
Old Jul 30, 2015 | 09:17 PM
  #57
voda1's Avatar
Old Jul 31, 2015 | 12:43 AM
  #58
Titokang's Avatar
Originally Posted by voda1
Tell me about it, called some local machine shops and nobody wants to touch my engine because its aluminum. Got a text from a buddy and ha Pulled 890 rwhp from his 5.3 pt88 setup so it's got me thinking Lolz. Its gonna be awhile, more than likely swap a 4.8 in the slomaro for now since the engines been on a stand for year, just wanna drive my car no matter what the power
Old Jul 31, 2015 | 12:55 PM
  #59
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Dammitt man... Bad luck. Just horrible
Old Jul 31, 2015 | 01:36 PM
  #60
the MAST small bore rectangle port curse continues..........
