Mast head swap
Old Jul 31, 2015 | 02:02 PM
  #61
scotty2000ss's Avatar
This sucks. Will we ever get to see what these heads can do?
Old Jul 31, 2015 | 08:25 PM
  #62
Titokang's Avatar
Give me some time guys, I'll get it going again. Got referred to 2 different builders yesterday so I need to call em up and see what they say. From what the other shops told me I'm better off buying another short block but we shall see.
Old Jul 31, 2015 | 10:58 PM
  #63
SCott5's Avatar
I think I'm going to go with these heads with my boosted setup. So get this done haha
Old Aug 3, 2015 | 08:46 AM
  #64
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'm going to toss something out here. Feel free to throw it back:
Remove the damn factory bolts. Helicoil or timesert the stripped inners that are only going to see 25ftlbs anyway.
Grab a ProComp (eBay) headstud kit and be done with it. Plenty of boosted setups running these studs without issue at all.
And I really dont see WHY a builder would say the SB is trashed... We're talking about repairing the threads that aren't seeing all that much torque.
Heli-coil, ProComp studs,
Old Aug 3, 2015 | 12:31 PM
  #65
Rise of the Phoenix's Avatar
You and that logic of yours again Dave. Don't you know that's got no place here.
Old Aug 3, 2015 | 02:18 PM
  #66
Darth_V8r's Avatar
Moderator
We only make horsepower around here. Not sense.
Old Aug 3, 2015 | 05:33 PM
  #67
A.R. Shale Targa's Avatar
Stop right there Dave; if the OP fixes that block how will the Schlitz brewery make more cans of beer this week
Old Aug 4, 2015 | 03:36 PM
  #68
Titokang's Avatar
Haha you guys are nutz, besides I'm more of a corona/ dos x's type of guy. Builder said it's fixable but he has a lot of work and probably run me 400 to fix. For 1000 I can get a complete lq9. Sell off the top end and my ls1 and not be out too much into it. I read the pro comp head studs run a little short in length, is that true? The decks on these things are pretty beefy, not too sure how theyd work out.
Old Aug 4, 2015 | 04:36 PM
  #69
dr_whigham's Avatar
The Scammer Hammer
I personally think the small bores would REALLY shine on a 4.0 bore, with flat tops (LQ9) to boot.
Pull it and go for it!
Old Jul 12, 2019 | 12:56 PM
  #70
Titokang's Avatar
Old Jul 12, 2019 | 12:57 PM
  #71
Titokang's Avatar
Back from the dead the car and thread
Old Jul 12, 2019 | 03:48 PM
  #72
Sounds killer. Did you go with the LQ? How does it run?
Old Jul 12, 2019 | 08:30 PM
  #73
AINT SKEERED's Avatar
Should do close to 500. Very nice
Old Jul 14, 2019 | 01:03 AM
  #74
Titokang's Avatar
Still ls1, did a timesert kit and havent driven it. Just idle time making sure it's got good pressure and not overheating but I have an ls3 map and it's got a slight misfire on both banks so needs a retune, after 4 years of sitting it ain't to shabby idling on its own
Old Jul 14, 2019 | 01:05 AM
  #75
Titokang's Avatar
Ended up doing chs trunion kit and racetronix pump with a hotwire and fired right up, hopefully next week retune and drive it for a bit
Old Jul 14, 2019 | 07:07 AM
  #76
I had problems with one of my ls1 blocks before. Starter bolts and rocker arm bolt holes had to be heli coiled as the block got brittle. Pulled threads out..
Old Jul 14, 2019 | 09:22 PM
  #77
Tang2's Avatar
Sounds great, looking forward to seeing your results!
