Mast head swap
Old Jun 8, 2015 | 02:13 AM
Titokang's Avatar
Default Mast head swap
Getting ready to slap my engine back together with some mast small bore ls3's and a new cam. Getting close, hopefully this coming week I'll have everything together minus a new fuel pump since mine took a dump couple weeks back and been buying gaskets and bolts lately. Not a drag car just want it to at least trap 123 that's my goal. Setup consists of mast ls3 heads with Btr platinum springs with seats/retainers/locks from ed Curtis. Comp 3/8 pushrods, morel 4708 lifters and ls2 trays, 226/242 630/604 114+4 eps cam. Gm mls head gaskets, edelbrock Victor stepped headers with a custom y pipe that runs to a vibrant 3-4" merge, dynomax 4" race muffler. 6 speed car with 3.42's monster level 2 clutch with a tick master and speed bleeder. Deep dish zr1's on 315 toyo tq drag radials. Hopefully runs good
Old Jun 8, 2015 | 02:14 AM
Titokang's Avatar
Old Jun 8, 2015 | 02:15 AM
Titokang's Avatar
Old Jun 8, 2015 | 02:18 AM
Titokang's Avatar
Old Jun 8, 2015 | 03:29 AM
HCI2000SS's Avatar
Should be a very stout setup. Keep us posted
Old Jun 8, 2015 | 11:44 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Should be interesting...
So the valve locks and associated hardware are different from Brian's regular setup with his springs? I remember he told me the kit he had wouldn't fit the heads when I had them, which I why I went the PAC1221x route.
So when are you looking at first start up?
Old Jun 8, 2015 | 12:51 PM
Rise of the Phoenix's Avatar
Looking forward to this one.
Old Jun 8, 2015 | 01:07 PM
scotty2000ss's Avatar
Awesome. Really looking forward to seeing the graph and trap speed on this build. Congratulations
Old Jun 8, 2015 | 03:26 PM
Titokang's Avatar
Yeah I bought a Btr kit and got in contact with ed and he sold me the hardware. Took a .060 shim and .100 seats to get the spring height at 1.783. Looking forward to sharing results but won't be for a couple weeks to fire it up and get it retuned. Thanks guys
Old Jun 8, 2015 | 06:33 PM
JaSSon's Avatar
I'm in
Old Jun 8, 2015 | 07:16 PM
voda1's Avatar
cc's/compression ratio?
Old Jun 8, 2015 | 07:48 PM
HISS's Avatar
Subbed for results as well.
Old Jun 8, 2015 | 08:55 PM
Titokang's Avatar
Static should be 10.8 if I remember correctly, and I need to calculate dynamic. Probably do that in a bit since its been raining like crazy and can't do much on the car anyway. Also need to order some fuel rail spacers from katech and new plugs now that I remember. I thought they used gasket style plugs but the plug holes are tapered so I need to look into that.
Old Jun 8, 2015 | 10:08 PM
A.R. Shale Targa's Avatar
BALLER.......
Old Jul 5, 2015 | 10:40 PM
Titokang's Avatar
Old Jul 5, 2015 | 10:42 PM
Titokang's Avatar
Old Jul 5, 2015 | 10:43 PM
Titokang's Avatar
Old Jul 5, 2015 | 10:52 PM
Titokang's Avatar
Been awhile since I've updated my thread, getting closer. Tomorrow I get a chance to work on the car well see how far along I get. Rollmaster billet single roller timing set, melling 10295 oil pump, cam retainer plate with recessed bolts, ngk bkr7e plugs. Now I just gotta figure out how to remove the mast rocker stands. They're set in place with dowels, I installed em to install the valve springs with a comp cams spring compressor. Took some whacks with a rubber mallet to seat em now I can figure out how to remove them. I need to take them off because the head bolt holes are blocked with them installed. Tried a pry bar with a towel and left a little mark on the head, last thing I wanna do is damage anything. Anyone with experience working on etps or mast heads with rocker stands feel free to chime in
Old Jul 6, 2015 | 07:32 PM
RUNUDWN99T/A's Avatar
what engine size are you putting these on?
Old Jul 6, 2015 | 08:51 PM
dr_whigham's Avatar
The Scammer Hammer
It's a 346 if memory serves me right.
