Trick flow vs ported 799 heads
Old Jun 25, 2015 | 07:21 AM
ssjason232's Avatar
Default Trick flow vs ported 799 heads
Hey guys,
Planning out a heads and cam project on my Z. I have an opportunity to possibly pick up some 799 heads for cheap then sending them off to say AI to be ported. Question is, am I better off doing this or just buying off the shelf trick flow heads.
Thanks for the advise.
Old Jun 25, 2015 | 07:32 AM
HCI2000SS's Avatar
Which TF heads?
Old Jun 25, 2015 | 08:45 AM
ssjason232's Avatar
Sorry, should have mentioned that. Was looking at the GenX 215s.
Old Jun 25, 2015 | 08:49 AM
HCI2000SS's Avatar
A good set of ported 799 heads will do better than stock TF 215's
Old Jun 25, 2015 | 08:55 AM
MonmouthCtyLS7's Avatar
Hard to beat the value of sending out some 799/243's to AI if cost is any concern.
Old Jun 25, 2015 | 09:19 AM
Darth_V8r's Avatar
Moderator
AI can port those to 226 and get pretty damn good results out of them.
Old Jun 25, 2015 | 09:26 AM
HCI2000SS's Avatar
Exactly!
Old Jun 25, 2015 | 09:59 AM
Rise of the Phoenix's Avatar
Or you could opt for the 232cc option.
Old Jun 25, 2015 | 10:50 AM
A.R. Shale Targa's Avatar
The other apples to oranges compare is the GM powdered metal guides where the TFs have the bronze guides. The only Trick Flows that have the PM guides are the CNC205s which offer 300 cfm of flow and tremendous compression with 58cc chambers.....at 1160 a piece they are considerably more dinero than some AI 799s.
Old Jun 25, 2015 | 04:14 PM
ssjason232's Avatar
Looks like 799s are the way to go. now I just need to buy them.
Thanks guys.
Jason
Old Jun 25, 2015 | 04:39 PM
edwardzracing's Avatar
This is an old article, but it's been super helpful to many:
http://www.hotrod.com/how-to/engine/...der-head-test/
Take note of how the TEA ported LS6 heads did in comparison to the bigger heavy hitters. Financially it makes a lot of sense to get some 799's and have them ported. Good luck!
