Rods and pistons?
Old Jul 5, 2015 | 03:39 AM
HappySalesman's Avatar
Default Rods and pistons?
Hey all, looking to do a bottom end rebuild in my z, and ran into an issue.
I want to replace the piston and rods with forged parts, to give me a really solid foundation for my build.
However I can't really seem to find any pistons that fit the stock bore? The closest I saw was 3.903. If I wanna do this build, am I gonna have to get an overbore done?
Old Jul 5, 2015 | 04:42 AM
J0SH's Avatar
Normally people bore out a stock bore when they go to a forged setup. The stock cylinders never seem to be completely straight.
Old Jul 5, 2015 | 11:44 AM
Ah okay. Is it common to go with longer rods as well, or is that just for people wanting a stroker setup
Old Jul 5, 2015 | 12:36 PM
KCS's Avatar
KCS
Moderator
Depends on the piston, but usually you will want to use a 6.125" rod. The Scat I Beams are nice for mild builds (<600rwhp) and are pretty inexpensive.
Old Jul 8, 2015 | 11:36 PM
this will probably sound really nooby, but with the slightly longer rods, what overall would change in the engine? I know obviously the piston will sit .127" higher in the cylinder, but at that point am I looking at having to flycut pistons or add valve reliefs?
Old Jul 9, 2015 | 03:32 AM
Quick Ranger's Avatar
Most aftermarket pistons will be set up to use a 6.125 rod with a .927 pin. They will also have valve reliefs already.
Old Jul 9, 2015 | 09:04 AM
KCS's Avatar
KCS
Moderator
Stock rods are about 6.098" center to center, so a 6.125" rod is actually only .027" longer.
Aftermarket forged pistons will usually have a reduced compression height (distance from wrist pin centerline to top of piston) at about 1.300-1.305". They normally already have valve releifs cut into them, so you don't normally have to worry about that.
Old Jul 9, 2015 | 10:37 AM
TyCZ28's Avatar
Texas-Speed makes some nice Piston-Rod combos for what your looking for.
https://www.texas-speed.com/p-4487-t...22-stroke.aspx
