MMS 220 Build for "Ghost Hawk"
You guys are like related or bonded by fate or something now.....LOL
And Darth.....Gluemaker is your FATHER!!
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
I tried something, figured the worst that could happen is i'd just unplug it if it's off - I ratioed up the MAF table values from 78mm to 102. Now, since it's an area function, the ratio was 51^2 / 39^2, or 1.71:1. I know it isn't perfect, but I think it's fairly close. This morning, I plugged in the MAF, and instead of hunting for idle, she just fired up, went straight to 1200 and then dropped to 900.
So, I drove her to work, and for about he first mile, there was some bucking as the fuel trims and closed loop tables started learning themselves, but after that, she got smooth and powerful.
Still have this wicked high fast idle (1500-2000 rpm). If the wheels are moving even 1-mph, it idles high. Once it comes to a dead stop, it drops in. Not sure if that is adaptive idle or DFCO or something as yet undiscovered. Still learning the acronyms and nomenclature.
I should be getting a professional tune on Friday anyway, but I like knowing how things work, and I'm not pulling her hard anyway.
Also, the air adder was set to engage at 2mph and disengage at 1 mph. I changed this to 82 and 81. So, the fast idle won't kick in at all, allowing the adaptive idle to just work.
I'll drive it in about an hour and see how it does.
So, on to the cranking tables...I think
It's sill rich as hell, but at least it fired right up instead of sort of lazily coming to life.
Dyno time scheduled Friday 4pm pacific
