Timing chain Snapped?
Old Aug 4, 2015 | 11:58 AM
txh0tb0i972's Avatar
Default Timing chain Snapped?
Whats up tech memebers !
Well last night "Zepp decided to shut off on me.
From the sounds of it i am thinking the timing belt snapped but I will confirm later today once i pull valve covers.
But I wanted to get some feedback and opinons from my fellow members.
So i was at about 4k rpm, had a back fire (valves not opening/closing as they should My opinon) then shut off and coasted to side.
When i attempted to turn it on, the motor turns and all but it will not start.
My engine is an LS6 with valve relief pistons, cam is a 238/244 586/596 on 114lsa.
I know if the timing chain snapped there is possiblity of valves being bent and pistons being damaged.
Do you think the valve relief and dual valve springs saved me from any damage?
any input is greatly appreciated.
Old Aug 4, 2015 | 12:03 PM
Darth_V8r's Avatar
Moderator
If your timing chain went you bent some valves. It's interference engine.
I've busted three on various engines. When you bump the starter they don't chug due to no compression. It sounds like an electric drill spinning.
Old Aug 4, 2015 | 12:04 PM
96capricemgr's Avatar
More likely a spring thEn chain.....
Old Aug 4, 2015 | 12:06 PM
yes .... i was going to put that in my description but i couldn't find the sound.
Old Aug 4, 2015 | 12:54 PM
Darth_V8r's Avatar
Moderator
Sorry for your loss there. Here is how mine went if this helps:
1. Nissan 1.8L bent every valve. Put dents in the piston surface. No other damage. New valves and guides. Milled 004 to clean up the surface. Ran fine after that
2. BMW 2.8L. Bent some valves but not all. Guides were ok. Replaced all valves to be safe. Ran fine on reassembly.
3. Toyota 2.2L. Non interference engine. Literally no damage. Installed new timing set and running fine.
Old Aug 4, 2015 | 01:05 PM
svede1212's Avatar
FWIW my chain snapped when I had a "Street" link bar lifter break jamming the cam. I bent 9 valves and that happened on the first few revolutions of startup.
Old Aug 4, 2015 | 01:44 PM
i was hoping maybe there was no contact with the piston having valve relief.
I will find out once we look in to it.
Old Aug 4, 2015 | 06:09 PM
svede1212's Avatar
Unless the relief is more than 1/2" deep you probably had contact on some
Old Aug 5, 2015 | 10:27 AM
I figured... ... oh well ill see once i pull them .
Old Aug 5, 2015 | 02:07 PM
RGSS's Avatar
How many miles on the chain?
Old Aug 6, 2015 | 05:43 AM
joecar's Avatar
What crank pulley/damper do you have...?
Old Aug 6, 2015 | 07:45 AM
squalor's Avatar
You refer to that issue with a certain 25% underdrive pully linked to broken chains ?
Old Aug 6, 2015 | 07:48 AM
if im not mistaking its a ASP underdrive pulley.
Old Aug 7, 2015 | 10:57 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
What timing chain were you running?
Old Aug 7, 2015 | 12:08 PM
Timing chain snap is basically instant, if you heard it begin to breakup my money is on valvesprings and whatever carnage followed
Old Aug 7, 2015 | 12:39 PM
ls2 timing chain
