Mamo 220s in 383 stroker
F-Body accessories.
This mod turns the sensor 90* counter-clockwise so the connector is down and it clears the firewall easily. I drilled a small hole in the FAST and used a sheet metal screw with a washer to secure the sensor in. You can't see any of it installed on the engine.
Too bad my pretty "Mamofied" heads are mummified and hidden. The red plate on the left is for my Engall's Stiffy torque damper.
This won't interest fbody or Corvette guys but for the few GTO owners this is my ducting of the front kidney grills. It is part of the effort I made when I developed my "Svede" OTR intake. I don't believe in "Ram Air" but I do believe in ambient temp air and the kidney grill "scoops" deliver it directly.
. 13 days for Manton from order to delivery in Michigan so if you order be prepared. I'll be disappointed if I can't get a good tune in it and get it dynoed before winter gets here.
Come on UPS! Get here.
It fired right up but died about 20-30 second later hunting for idle. I tweaked a coupe of things and got it running. My garage air was barely breathable from all the smoke. I pulled it outside and let it idle and warm up while checking for oil, coolant and fuel leaks. Everything looked good so I piled the wife into the car and we took it to 5 Guys for some burgers and fries.
It's in closed loop so fueling looked good. I have a dash AFR gauge that runs full time. Because WOT goes to open loop I only gave it a coupe of little blasts. The throttle was very responsive and the tires very slippery
.A tropical storm from down south is almost here with a lot of expected rain so it will be Friday at the earliest I can get to tuning it. After 4 weeks I'm just happy and relieved it's running again.
