Mamo 220s in 383 stroker
Old Oct 27, 2015 | 08:22 PM
  #141
98_WS6_M6's Avatar
Awesome! Congrats! Looks sick!
Old Oct 27, 2015 | 08:46 PM
  #142
svede1212's Avatar
My back and every joint is aching right now. I's going to be hot tub tonight.
Old Oct 27, 2015 | 09:07 PM
  #143
dkota1968's Avatar
Badass man, have fun with it and enjoy!
Old Oct 27, 2015 | 10:52 PM
  #144
5_litre_eater's Avatar
Congrats! It must feel great to be done!
Old Oct 28, 2015 | 06:12 AM
  #145
tuckin22's Avatar
Heck yeah man. Congrats.
Old Oct 28, 2015 | 08:58 AM
  #146
Darth_V8r's Avatar
Moderator
The throttle was very responsive and the tires very slippery .
Yeah, I think you're next big problem is traction. Are you running stock tires? I ended up throwing a set of 2012 corvette take-offs to get 305's on the back and help with that.
Old Oct 28, 2015 | 10:36 AM
  #147
svede1212's Avatar
GTOs suffer from a very limited space to fit wheels and tires. We also have a funky 120mm lug spacing. They came stock with 245s. I had my stock 8" wide 17"s widened to 9" and with fender rolling and a BFH to the inner fender managed to put 285s in along with full poly bushings to hold the wheel in place. Remember we have independent suspension too.
I went to a Nitto NT05 275 now as that was the closest size they offered that works. I've tried drag radials before and the small amount of increase in traction was outweighed by the cost of having to replace them all the time. It's pretty cool out here right now which isn't helping the summer tires either.
Old Nov 3, 2015 | 11:12 AM
  #148
svede1212's Avatar
Just an update. We finally got some beautiful fall weather, sunny and in the 70s, and I got a little street logging in. It is running very rich (before my adjustment) but I spooled it up to 7 grand in 3rd gear a couple of times and it went quickly and smoothly. I know it's just my butt-o-meter but compared to before it is carrying power way up which is encouraging for big numbers. More work to do and I'm still fighting a little idling issues when coming to a stop. The weather is 180* different than last year and let's hope this hangs on a while.
Old Nov 3, 2015 | 12:52 PM
  #149
DavidBoren's Avatar
Where do you live that the weather fluctuates 180° in a year?! Lol.
Good luck fighting those last little gremlins. When do you think you will have some numbers to share with us?
Old Nov 3, 2015 | 01:34 PM
  #150
unit's Avatar
With a tune, it sounds like you'll be ready to go! Congrats!!
Old Nov 3, 2015 | 01:52 PM
  #151
svede1212's Avatar
In Michigan it can do that in an hour.
I know it's not an exact science but some of my impression of the heads/cam I get from my VE table fueling. Part of my top end gain is a better valve train but even down lower around peak torque my initial tuning is showing a 10-15% higher fueling rate with these heads from 4,000 rpm on up for the same 12.8 AFR at wide open throttle.
Old Nov 4, 2015 | 04:06 PM
  #152
Darth_V8r's Avatar
Moderator
My VEs went up like that as well. I think it's about the best indicator you have short of a dyno jet.
Old Nov 4, 2015 | 04:18 PM
  #153
svede1212's Avatar
I agree. With more air packing in more fuel is needed to maintain AFR
Old Nov 4, 2015 | 09:03 PM
  #154
conan's Avatar
Good to see you got her all put back together. Any plans to get the car on the rollers this year ?
Old Nov 4, 2015 | 11:26 PM
  #155
Camaro99SS's Avatar
Congrats on the completion! Any plans to get on a dyno soon? I'm also curious how quiet the valvetrain is with these lifters when set up properly.
Jason
Old Nov 5, 2015 | 08:01 PM
  #156
svede1212's Avatar
I'm trying to get dyno time lined up before the snow gets here. They're talking about some next week
Old Nov 5, 2015 | 08:53 PM
  #157
98_WS6_M6's Avatar
Sweet. That's exciting. I'm pumped to see what power you make also. I did the 383 stroker this past winter and the Mamo 220s are sitting on my spoiler now waiting for me to get some time for install. Probably start next week.
Old Nov 5, 2015 | 11:35 PM
  #158
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Congrats!! Looks great also under the hood also
How is the idle quality and street manners etc?
Do you have that part of the tune dialed in yet?
Really glad to hear its in the car, running well, and the install is behind you!! (most importantly.....LOL)
Cheers,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Nov 6, 2015 | 09:24 AM
  #159
svede1212's Avatar
Cheers,
Tony
Oh course WOT fueling is easy but I've been fighting stalling and surge when coming down to idle. I think I got that ironed out yesterday with more tweaking of idle fueling and air flow related tables. Until I get to a dyno I've set my timing at 26* and I have yet to get any knock at WOT. The street manners are very good. I don't see much difference in that regard from my old cam, just what I wanted. The higher overlap is making my exhaust a little smellier at idle/low rpm but that's it.
I have to get back into the rocker covers as it seems to have tapping that I think is abnormal. Changing cam and rockers make it a little nosier? To be safe I'm going to recheck the rods. I have Lunati (Morel) high rpm, short travel lifters so the preload is pretty light too. I'v been reading that the block grows about .010 when hot and maybe that has something to do with it. Like I said it pulls up to 7 grand in a heartbeat and I have to be careful in the first three gears going WOT or the back end wants to pass the front.
Old Nov 6, 2015 | 09:31 AM
  #160
tuckin22's Avatar
7000rpm is one thing I can't wait for. My setup now tops out at 6400. The graph was a continuous smooth climb so would be excited to see what happens with a set of these.
Still though congrats on getting it back on the road again at least.
