Recommend a cam for a built LQ9
6.0 iron block bored to 6.2L
LS2 crank/rods
Forged pistons with valve relief
PRC 225 as-cast heads (62cc) with PRC dual spring .650 lift
stock rocker arms
11.4:1 CR
long tube headers
Fast 102 intake
Morel lifters
manual trans
Ford 9" 3.55 gears
26" tall tire
Car is not a daily driver but driven often in the summer. Maybe 4000 miles per year.
I checked Texas Speeds website and was considering the Tsunami or MS4 cams. Any thoughts on those or other cams?
thanks
I would do something like the Cam Motion Penetrator 230/238 .637/.620 112+4. That would be plenty rowdy in the 376cid motor, but would drive nice and make good power with the PRC 225 heads.
We have great new things coming out of Texas Speed!
Our number is 512-863-0900.Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
Lonnie @ TSP recommended the Tsunami (235/240 .622"/.615 111LSA)
Kip @ CamMotion recommended (228/630/236/612/113+4) I think he thought the penetrator would be too much
A lot to think about. Thoughts?
Personally, if you don't have a kickass tuner (not for a dyno number - I'm taking the time it takes to dial in drivability), I wouldn't even consider the first two. And I'm serious as **** on that. I dialed in my cam, which is the size of the TorqueMAX 3 and I would never buy that cam again. It drives fine for what it is, but it's still not what I would ever recommend to someone else. And I don't have any bucking/surging/hesitation - because I spent a lot of time dialing that out of the car. AND I have a 4200 stall. And it's still not what I would consider ideal for a car you plan to actually drive on the street. It's a beast when you unleash it. And I can live with it in traffic. In fact, I don't mind it and drive it around a lot now that I got the tune ironed out. But, I could see that it would be an issue for other people.
Part of the issue is we are using old, slow *** PCMs, and a slow to react IAC. In an LS2 or newer Vette, they are fast enough to tame a lot of the issues with big cams.
BTR mainly uses Comp. I don't know if they have been using Cam Motion or not, but back at the end of July when Brian and I were having a conversation he mentioned that they had not had a cam ground by Kip yet. That has probably changed by now.
We have been using Cam Motion since about February of this year for 95% of our cam grinds.
As Kip mentioned, all of our lobes at Tick are proprietary and are ground to my specific specifications.
Also, that is not the cam that I originally recommended either. I did recommend something much smaller. The customer insisted on a larger camshaft and I'd rather see him in a Tsunami camshaft then our MS4 given his combination. The Tsunami makes about 5rwhp less than the MS4 but has A Lot better street manners. Sometimes people just want a huge cam.
Lonnie
For how you describe wanting to use the car I would stick with something similar to what Kip and it sounds like Texas Speed originally recommended. You will love the power from idle to redline instead of getting something too big you have to wait on to come in.
Engine specs:
4.065 bore
3.622 LS2 stroke
LS2 stock rods and crank
4.080 head gasket bore
.051 HG thickness
58.5cc chamber
-5cc piston valve reliefs
0.015 piston above deck
Cam specs:
Intake valve close 46.2* ABDC
I keep coming up with a crazy number, doesn't make sense.
thanks
