View Poll Results: Can it Be Saved?
Yes
25
83.33%
Nope, it's scrap.
5
16.67%
Voters: 30. You may not vote on this poll
Can This Block Be Saved? 4.250" Stroke LQ9 Build Thread
#141
I just know the pain of going outside expecting to drive somewhere and ending up using a fourth car to go get parts for the other three. Especially awesome when the HOA **** comes by complaining about you working on your **** in your driveway (which is allowed if you get it done or in garage before dark). Then you end up threatening ppl to either help or get the eff off your property. I'm not bitter
Works great for Jehovas Witnesses. FWIW.
#143
New update. Daily drove this car for a few months, roughly 50-60 miles a day. I got some tuning done and got it running really well, but must be getting old or just used to driving the Caddy, because I just did not enjoy it as a daily driver. So I’m making some changes to make it more “old man friendly.”
The heads on it now are stock 317 cathedral ports with a FAST 78mm intake and stock MAF and MTI lid. I picked up some L92 heads and got them cleaned up with a fresh cut valve job using some SAM profiles, and skim cut the deck surface. Also got a stock LS3 intake with rails, injectors, and adapters to run in a F-body. Throttle body is a WARR 92mm and I think I’ll fabricate a 4” intake tube to run over the radiator and place the air filter behind the front bumper.
The cam now has 243/251 degrees of duration and .369”/.372” of lobe lift. The rockers are Comp Ultra Pro Mag with a 1.8:1 ratio, which puts the valve lift at .664”/.670”. LSA is 113 and installed at a 110 intake centerline. Thats an IVC of 51.5 degrees and 21 degrees of overlap.
The new cam will be none other than the Summit Racing 8715R1, aka The Ghost Cam. I know it’s teeny tiny for a 440ci shortblock, but this cam will drop the IVC down to 43 degrees and overlap with be -2 degrees, so it should be very civil and easy to drive everyday. The lower lift of the Summit cam also allows me to go back to stock rockers, which I’ll be upgrading with a BTR shaft rocker kit. The springs are from BTR as well with tool steel retainers.
The old top end is already off and while we get hit with this freeze for the next couple days, I’ll get the rockers cleaned and assembled, and then do some bowl blending on the heads and get them ready to go on.
The following 2 users liked this post by KCS:
CattleAc (02-02-2022), Che70velle (02-02-2022)
#144
Excellent plan, however at that displacement I would also consider the SDPC ls9 PowerMax camshaft as it's a 216/239-120+4 with around .600 lift and you could mill the heads as much as you want for at least 12:1 static
The following users liked this post:
02*C5 (02-02-2022)
#146
Nobody has mentioned what looks to be a crack inside the intake bowl.
01CamaroSSTx (02-04-2022)
#148
The throttle response was pretty wicked though. It made the car feel explosive with very little throttle opening or RPM. I'm hoping the small cam and bigger heads help keep some of that throttle response while allowing it to pull to higher RPM.
01CamaroSSTx (02-04-2022), Homer_Simpson (02-05-2022)
blackdak318 (11-23-2022)
