Max overlap for 0 lope ?
Thanx in advance for any replies.
For compression, I'm shooting for around 8.5 DCR. Does more compression tame lope or make it more pronounced ?
To me, "0 lope" would sound like a steady burble with no hunting for idle. I would guess lope would be determined by overlap @ 0.006 so XE-R lobes (49) would be smoother than HUC lobes (55) of the same .050 duration.
Would you say less lope = more throttle response ?
Compression ratio (static) does increase sound intensity and the manifold vacuum which not only helps smooth the idle but sharpens the throttle response . Maximizing cranking compression or DCR within fuel limitations is what Mamo always describes as explosive...that butterflies in the tummy feeling you get from the power band seemingly there no matter the rpms....LOL
I'm glad you asked about this squalor...I'm going to start my forged 6.0 "stealth sleeper" build and would like to have the optimum performance with a stealthy idle...
It's not that I want to be stealthy as much as I want throttle response. If -2 overlap makes enough manifold vacuum that I have fast throttle response off idle then maybe 0 overlap would give the same throttle response at 1200 rpm and +2 overlap would give snappy throttle response at 1800 rpm.
PREDATOR_Z once said that every degree of positive overlap is worth 2 hp (rough estimate). I'm more into driving fast on twisty roads than I am drag racing. I'm willing to give up peak horsepower to gain fast, predictable throttle response.
Another theory I've sort of seen kicked around is that it's the 006 to 006 overlap that makes for choppiness. I think I've come to the conclusion that isn't true, that the 050 number is more critical to idle chop. The comparison I'll make to illustrate is the Comp XER273 vs a stock LS1 cam.
At 006, the stock cam has 47.5 degrees of overlap vs 48 for the comp. At 050, the stocker is -34.5, and the comp is -1. So, for almost the exact same 006 event, the behavior is completely different. Since I once ran a comp XER 273, I can tell you first hand, it does not idle like stock.
I propose that the "lift area" of the overlap event will ultimately determine the propensity for lope and surge. So, increasing the ramp rate at the same 006 overlap duration OR increasing the 006 duration at the same 050 duration would increase lope if that theory is correct. Another way to look at it is to increase the rocker ratio from 1.7 to 1.85. The 006 events are the same, but the valve opens and closes faster, so I would expect the idle to lope more.
Remember, idle chop is really just a vacuum leak at the valves, so it's about how much of a leak you create. Wider cracks leak faster than narrower cracks.
But, I've also found that there is a ton that can be done in the tune to affect it as well. If you define "lope" as hunting for idle speed, then mine doesn't lope. If you define it as the "choppy" or "popping" sound you get with each cylinder pulse, then mine lopes and it's awesome. Tuner did a hell of a job with injector timings, spark timings, etc, and really tamed the cam, and once the coolant crosses 140 degrees, it idles smooth. I think there is a whole lot more to be said, but I want to be careful not to hijack the thread.
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
Anyways, superchevy magazine did a ls3 cam comparison where they established a manifold pressure measurement on "driveability". Their definition of streetable was a 950rpm idle, or lower, no lope/shake or searching at idle, no surging or bucking at low speed or partial throttle. And there empirical testing concluded that 35-45kpa manifold pressure is your typical production car with a factory cam. 50kpa is still streetable. And anything above 70kpa manifold pressure has noticeable shake at idle, stumbles upon coming to a stop, typical "big cam" poor driveability issues.
Something to consider is that all the factory cams, with the ASA cam being the only exception, have negative overlap @ .050", and all the factory cams have zero lope, smooth idle, etc...
The superchevy article said there is a direct correlation between increasing overlap and increasing manifold pressure. And they used manifold pressure as the meter for measuring driveability.
I would think it's safe to say that negative overlap @ .050" will make for a "stealth" and streetable cam. And any positive overlap @ .050" starts to become a trade-off of how it behaves down low, versus the gains at the top, and that's all dependant on the driver's personal tolerance levels for what is considered "streetable".
The tune can play a lot into "lope". You can smooth out a big cam by adding fuel, timing, and a bit more idle speed.
Conversely you can make a small cam sound nasty by doing exactly the opposite.
And I mean a badass set of heads like the Mamo220's, TFS220's, or AFR215's. Couple them with a rather mild cam, say the cammotion stage 4 drop in for 5.7L - 220/224-116+3 with events -3, 43, 51, -7. Has -10 degrees overlap. Fast92/92. Run a .041"head gasket, have the heads milled to 62cc's.
Assuming stock bottom end, that all puts you at 11.15 SCR, 8.53 DCR. Should run fine on 91 octane (93 would be better). The throttle would be nice and snappy, lobes are relatively mild, so your valvetrain will be nice and stable, port velocities from the heads will improve cylinder fill, even without the cam to support it.
That would give you a very broad torque curve, smooth application of power, tame idle, and nice, snappy throttle response, no gas smell, and will probably embarrass a lot of over-cammed, stock-headed cars on the street.
There are no MMS 220's in my future and the only after market casting I could consider would be redtan's AFR 205's. I've been saving since last Christmas and only have $1300 , it's hard to put money back on a security guards wages.
When I first started studying cams, I thought I wanted a El Toro (230XFI/230XE-R 111 +2) but my latest "Cam of the Week" is a 223/230 112.5 +1. If I'm going to lope at 2* I might as well lope at 8* . A cam with -12* overlap sounds like a old man cam. I may be 57 but your never too old to have a happy childhood.
https://ls1tech.com/forums/generatio...manifolds.html
Post #2
-10 to about -5 (@ .050")
Jason
is the key
