LQ4 or LQ9 BUILD
Old Oct 10, 2015 | 03:49 PM
helrazr355's Avatar
Default LQ4 or LQ9 BUILD
Looking to build an engine based on the LQ4 or LQ9 not sure which to get it will probably be a budget build but looking for some inputs and info. im new and looking for some guidance looking for a 500 hp. I am new to this sorry!!!!!!
Old Oct 10, 2015 | 03:53 PM
T/AWS6969's Avatar
this going into a manual or auto?
Old Oct 10, 2015 | 03:58 PM
helrazr355's Avatar
Auto!!!
Old Oct 10, 2015 | 04:02 PM
3GZJerry's Avatar
both engine are the same. only difference is the LQ9 has higher compression. If your going to build the block then it doesnt matter which you choose cause you will be adding new internals. You could however save money on buying LQ4.
Old Oct 10, 2015 | 04:04 PM
helrazr355's Avatar
I have a grand total of roughly $5000cnd so not sure where abouts taht puts me i can get an lq4 for roughly $1400
Old Oct 10, 2015 | 04:06 PM
helrazr355's Avatar
Was figuring some head work and cam thin head gasket, or even different head???????? But was figuring on using stock internals crank, rods, pistons
Old Oct 10, 2015 | 04:07 PM
T/AWS6969's Avatar
dont quote me on this but i have been told they are not the same. the LQ4 has a slightly different crank (longer from what i have researched) and you cannot use it with a manual (a t56 anyway). but in your case you should be fine...
Old Oct 10, 2015 | 04:11 PM
T/AWS6969's Avatar
found this bro. you might see it useful... https://ls1tech.com/forums/conversio...on-needed.html
Old Oct 10, 2015 | 04:25 PM
helrazr355's Avatar
Well it appears i will be looking for a LQ9 2002 to 2009 that gets me started!!!!!
Old Oct 10, 2015 | 05:37 PM
96capricemgr's Avatar
I wouldn't pay more than about a $400 premium for a LQ9 vs. LQ4 because that is about what it would cost to get 243/799 core heads to get the compression up on a LQ4.
A $5000 budget wont go too far depending on how ready the car is for the motor. Is this an already LS based vehicle with boltons or is this a retrofit? Signature helps us help you.
Old Oct 10, 2015 | 07:06 PM
helrazr355's Avatar
Its going into a 1984 buick gbody was a v6 stage 2 turbo car i have a retardely build 200r4 with trans brake and 4000 stall diff is well build car has ran in the 10's
Old Oct 10, 2015 | 07:42 PM
So budget has to cover CAI, headers, swap parts like mounts and on and on so don't get carried away looking at heads and cam.
Old Oct 10, 2015 | 08:17 PM
helrazr355's Avatar
The engine itself will not be in the budget i will have 5000 for swap and other upgrades
Old Oct 13, 2015 | 09:48 AM
gagliano7's Avatar
The 99-00 Lq4 had the long cranks. The others are the same as the LQ9's.
Old Oct 13, 2015 | 11:21 AM
TurboBuick6's Avatar
N/A or N20 - LQ9
FI - LQ4
Old Oct 13, 2015 | 12:37 PM
Rise of the Phoenix's Avatar
Both the LQ4 and LQ9 can be made with whatever compression you want them to be. Just figure out what compression ratio you're shooting for and mill the heads accordingly. It will also be contingent on what head gasket you choose to run.
Old Oct 13, 2015 | 01:38 PM
speedtigger's Avatar
Old School Heavy
That sounds great when you say it, but the more you mill, the less room you have for a good sized camshaft.
