For peeps with T&D rockers...
The ball-ends are type "H" which have 5/16" diameter ***** with 270° of the ***** exposed. Is this the end I want? Once I get it narrowed down, I'll order a set of 3/8" Trends or Mantons...
Also, the T&D stand bolts stick about 3 threads into the intake ports. Should I trim them that much to keep the airflow a bit cleaner?
Not sure if I can get a 3/8", or even a tapered 3/8" in there, as a 5/16" is just a couple thou off the short-side intake wall and that wall is very thin.
Anybody got input on the Ford "HH" ends? These are 5/16" ball tips with 270° access...
Any idea if those Ford "H" style ball-ends are OK to use and/or get accurate measurements from?
How thick is the port wall now?
I was able to maintain .125"-.130" port wall thickness with 3/8" pushrods,. but that was with the Dart heads.
Here is me fitting the Dart LS3 heads for T&Ds:
I have a link to my installation if you need it.
