trickflow 220 cast review
Old Oct 20, 2015 | 09:32 PM
SF 1HOTLS1's Avatar
Default trickflow 220 cast review
Ok guys i dont see a lot of ppl post there dyno numbers with these heads. I bought em new from brian tooley. Hand blended and miller to 60cc.
Before the heads i dynod 387 with a 228r cam n stock stall. Only change made were the heads and a yank pas 3400 stall. It made 425 on the same dyno. Same outside temps. I believe the converter easily ate up 10-13hp on the rollers.
The heads made great usable power from 3500-6500 rpm.
Old Oct 20, 2015 | 09:37 PM
sillysspeed's Avatar
That gives a good idea of how much the heads are worth power wise. Usually people change a bunch of other stuff at the same time. Any pics of the heads?
Old Oct 20, 2015 | 11:09 PM
SF 1HOTLS1's Avatar
No i dont have any sorry. But i will say the intake and exhaust runners were very clean as well as the chambers. Im hoping for a half second faster and 5 mph.
Old Oct 21, 2015 | 03:31 AM
HCI2000SS's Avatar
Nice comparison! I think 4-5 mph is realistic
Old Oct 21, 2015 | 07:40 AM
Rise of the Phoenix's Avatar
This is with a LS6 intake? What's the exhaust setup look like?
Old Oct 21, 2015 | 09:33 AM
SF 1HOTLS1's Avatar
Yes this is with a ls6 intake manifold 1 7/8 headers. offroad ypipe. Magnaflow 3 inch resonator dumped before the axle.
Old Oct 21, 2015 | 10:52 AM
thompson's Avatar
Nice solid gains! Great option for people wanting to save some money compared to the more expensive offerings out there.
Thanks
Aaron @ Thompson Motorsports
Old Oct 21, 2015 | 11:04 AM
This is just my personal opinion, but I truly believe that if you put this TFS 220cc head, worked by Tooley, up against heads like MAMO 220cc or MAST cathedral ports, you are going to see virtually no gains. Again, just my opinion. Oftentimes too many people "drink the Kool-Aid", and I think sometimes the Kool-Aid isn't all it's cracked up to be.
Old Oct 21, 2015 | 04:49 PM
great with an ls6 intake. Fast setup would probably be worth 25-35 more hp on that setup
Old Oct 21, 2015 | 04:58 PM
nzgreenfox's Avatar
Which heads did you have originally (ie the one that got you 387hp)? Thanks
Old Oct 21, 2015 | 07:16 PM
Kingc8r's Avatar
Nice gains Luis
Old Oct 21, 2015 | 07:30 PM
svede1212's Avatar
SAE or STD smoothing? What kind of dyno?
Old Oct 21, 2015 | 08:03 PM
saltwatercowboy6355's Avatar
How did the tq #s compare I was wondering how these would fare on my truck set up.
Thanks!
Old Oct 22, 2015 | 08:07 PM
SF 1HOTLS1's Avatar
stock 241 heads.
Old Oct 22, 2015 | 08:14 PM
SF 1HOTLS1's Avatar
Thanks!
i was disapointed. but again remember i added a 3400 stall. so like i said i think a few ponies and torque got lost their. my stock converter and cam only did 371 torque. it did 387 with the heads.
street tires used on all dyno passes for no power loss through sticky drag radials or slicks.
the dyno is one thing. im worried about the track though. im looking for a solid half second gain. once i go i will report back
Old Oct 22, 2015 | 08:17 PM
SF 1HOTLS1's Avatar
Originally Posted by Kingc8r
Nice gains Luis
ride on bro. im in the process of cutting the merge collector off my speed engineering y pipe to add the flowmaster 3-4 inch merge. then welding on a 4 inch resonator with a 4 inch dump before the axle. hoping to gain a bit their also.
probably shoulda did that before the dyno lol.
Old Oct 22, 2015 | 08:19 PM
SF 1HOTLS1's Avatar
its a superflow 880 awd dyno. and not sure on the correction
Old Oct 22, 2015 | 08:22 PM
SF 1HOTLS1's Avatar
you may gain a few horses but nothing to brag home about. money is spent better elsewhere. i can almost bet if i gained 5 tenths at the track with these and swapped em out for say the new mamo 220 heads it wouldnt change a bit.
dyno may show an extra 12 hp but doubt you will feel the difference or notice it on the timeslip. for a 346 i think these are great heads.
Old Oct 26, 2015 | 08:26 AM
Yep, another thread in here with a guy running these heads "touched" by Tooley and an Ed Curtis (Flowtech Induction) Streetsweeper cam prove these heads top of the line for a 346ci LS.
Old Oct 26, 2015 | 10:14 AM
DavidBoren's Avatar
That build absolutely surprised me, something like 480rwhp with tfs220's, ed c streetsweeper, and a mamo-fied fast92 intake on a stock 346 shortblock.
SF1hotls1, I think you are a ported fast intake and some true duals away from being dangerously close to 500rwhp. Keep up the good work.
