BTR Stage II/III vs Torquer V4
That said however my selection between the three listed is the
BTR Stage 2, reason being least amount of overlap, mid-upper
220s good intake duration for 5.7. Cathedral heads
typically need 4-6* more exhaust duration
Depending on exhaust port and system efficiency. Stage 3 has huge
(for NA) exhaust split of 11* VR4 has a little short 3* exhaust spit.
The stage 2 will drive better on the street and be easier to tune
Will provide a significant performance increase with your stock
Heads as well as ported or aftermarket.I would also look at the
Cam Motion Titan 4 227*/232* .612"/.595" 113*+4* similar
Numbers, with quality steel for cores and gentle lobes for more
Valvaetrain stability/durability @ high RPM and quieter operation.
Just My .02
Mine is up to 8 degrees of overlap on a manual is perfectly street able and very fun. I would bet auto could take more. My wife thought my old cam with 2 degrees was too lumpy.
Also, it seems there are still a few that are unaware but all of our cams have been redesigned using softer/more stable lobes and are ground on Callies cam cores.
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
