Do you need assistance? Farva out.
I need some GM guru's to help me figure this out. I've been trying to build a budget minded LS1 Iron block.
I've got an 03 5.3l block that I sent to the machine shop to be bored over to LS1 spec.
I already have the LS1 pistons from a corvette with new rings. Problem is the machine shop over-bored my block to 3.905"....not 3.898"...
Now I'm sitting here with pistons I can't use...
I've got Gen IV rods purchased threw this site and now i'm looking for 3.905" pistons that match with the 6.098" length.
I'm unsure of the Pin Diameter on the Gen 4 rods. I know there free floating, but are they still .945" or the smaller .927"??
anybody have a link to a set of pistons that match for under $600?
Thanks for the help in advance.
I know you already have the genIV rods, but I am having an equally difficult time tracking down some forged slugs for the 3.905" bore and stock 6.098" rods. So my choice would be to go forged rods and pistons, and raise the rod ratio in the process. Really can't beat the price of those eagle I-beams. They may be Chinese steel, but at least it's forged and shot-peened Chinese steel. They've got to be better than oem powdered metal rods.
PS. I know you said ~$600, man, and I'm not trying to spend your money for you... But I couldn't find you an option for the price you listed. Sorry.
JE has pistons that would work, PN 321240.
David, can't really go that route as I've already committed to the rods and there in route.
KCS, Those pistons might be the ticket. I don't see a listed PIN diameter on there website. If they are in fact .927" like the gen 4 rods. I'm in business. To be honest until I measure the rods or someone on here can confirm the pin diameter. I would make the purchase. But for the price. I'm just waiting on confirmation.
Old dude#1: Well, you could bore it out to 4." and sleeve it to the right thickness.
Me: The LM7 won't go past 3.910" without hitting water...
Old dude#2: You could run a larger piston in that cylinder only..
Me: ...internally balanced engine....no I won't...
Old dude#1: Well,..I could probably use it on a build later on if your looking' to get rid of it...
Me: I'd sell it to you if I have another block to build off of..but I don't.
Just came across this on another forum. Can anyone confirm the pin is .945" isn't that to large?
SKU JE-321240 Manufacturer JE Vehicle Make Chevy LS1 Bore Size 3.905 Wrist Pin Size 0.945 Piston Material 2618 Forged Compression Height 1.340 Piston Ring Size 1.5 1.5 3.0mm Piston Type Flat Top Rod Length 6.098 Crankshaft Stroke 3.622
SO, whats the harm in running pistons made for the 6.125 or 6.100" length rod on a 6.098"?
Are the pistons pin locations so different that they would promote Valve to piston issues?
Second, a piston pin bore will be about .945" so it has clearance with a .944" pin. The rods could be .945" as well in the Gen IV floating pin rods or .943" bore for the Gen III press fit rods.
Lastly, the JE piston PN I posted is for stock rods with the .944" pin. On JE's website, it has a note at the top that a K code comes with .944" pins and that PN has a K code. Keep in mind that they do not come with rings, those are extra. Don't assume the stock rings you have will work either. 3.898" bore rings will have a greater gap in a 3.905" bore by about .021".
Manley Domestic - Platinum Series Lightweight Pistons (592207C-8)
Bore: 3.905"
Rod Length: 6.125"
Stroke: 4.000"
Comp Distance: 1.115"
Comp Ratio: 11.2:1 @ 64cc,11:1 @ 66cc, 10.4:1 @ 70cc, 10.2:1 @ 72cc
Pin Diameter: .927"
Weight: 393g (w/ Pin 488g)
Piston Type: -4cc Flat Top
Bore: 3.905"
Rod Length: 6.125"
Stroke: 4.000"
Pin Diameter: .927"
To give you an example:
Zero deck on a 9.240" block would be a 3.62" stroke, 6.098" rod, and a 1.332" piston height. Bam, dead even with the block surface.
Same everything, except now you use a 1.305" piston, made for a 3.62" crank/6.125" rod combo, and you are .027" below deck. And that's too much to be ok with.
A 1.115" stroker piston would be a terrible .217" below the surface of the block.
If .027" below deck is the issue. what about a dome piston?
Diamond makes these.
Part #: 11526
Stroke: 3.622
Rod: 6.125
C.D.: 1.310
Weight: 481
Pin: .927 x 2.950
CC's: 10.0CC
Ring Set: 09063905
Bore: 3.905
Block Size: LS6
Would that increase the C.D. ?
I didn't mean to come off as putting words in your mouth. Just trying to measure twice cut once on this. I don't have them in yet, so I can measure.
Yes, those bushed rods should be bigger than .943" in order to have clearance with the .943" pin. In the sets I've measured, they're usually only about .0005" bigger, which is tight for a performance engine IMO. I like to just bump them through the rod hone for about .001" clearance. The LS7 rods are the exception; they use a .925" pin but that's a whole different animal.
