need a cam
Old Dec 19, 2015 | 08:01 PM
razorshot's Avatar
Default need a cam
Im in need of a cam for lq4 with ported 317 heads and longtubes ported intake manifold its in a 2001 Silverado 2500 im looking for a cam around this .050 .212/.218 .553/.553 lsa 113+2
.050 .214/.220 .553/.553 lsa 114
its a dd and I tow with it just looking to wake it up and have a little lope to it
any thoughts or advise is great
Old Dec 19, 2015 | 08:32 PM
saltwatercowboy6355's Avatar
Check out the truck in my sig. With the 3k stall it moves pretty good for the weight its pushing under 2000 rpm it's a little soft. If you have a good stall going in with it that would help a lot. I think the cams you have would be good for the lower tq range even if you give up a little up top
Old Dec 19, 2015 | 09:15 PM
2xLS1's Avatar
Google Trick Flow tfs-30602001
You'll find it for under $300 which is a great price for a new roller cam.
Old Dec 20, 2015 | 08:02 PM
razorshot's Avatar
ok thx
Old Dec 20, 2015 | 08:12 PM
Darth_V8r's Avatar
Moderator
If you want torque AND lope, see if you can get the first cam you listed cut on a 110 LSA.
Higher stall converters are great for acceleration, but might not be good for towing. I would check the auto trans section out, see if anyone in there has advice.
Old Dec 21, 2015 | 04:49 PM
razorshot's Avatar
would a btr stage 3 truck cam with one of his spring kits be a good dd/play/towing (not too worried about towing)package or would the spring be alittle overkill and just go with some .600 springs
btr stage 3 218/224 .553/.553 113+3
.660" Lift BTR Platinum Spring Kit
Old Dec 21, 2015 | 05:25 PM
Darth_V8r's Avatar
Moderator
Best person to ask is Brian Tooley. I would go with .600 springs, but that is me.
Old Dec 22, 2015 | 08:21 AM
Brian Tooley Racing's Avatar
The dual springs would be overkill, the beehive springs should work well.
We have the cam kit with springs for $419 shipped.
BTR Truck Cam Kit with Beehive Springs
Old Dec 26, 2015 | 07:29 PM
razorshot's Avatar
any bad reviews on the comp cam xr265hr cam
Old Dec 26, 2015 | 08:04 PM
madmike9396's Avatar
Check with Martin Smallwood . I'm sure he will spec you something great
