Connecting Rod Resize
Please weigh in.
Please weigh in.
If the rods are at the low end of the spec now and when torqued up with the new hardware and honed can then size under the top end of the spec, then yes he is right. There's a little confusion with this because the official spec for the LS/LQ series rods is 2.224"-2.225" but they use the exact same bearing shells as all the previous generation small blocks going back to the 60's for which the spec is 2.2247"-2.2252" If he can finish the rods to under 2.2252" then you'll be fine with the standard CB-663 style bearing which makes it much easier to mix shells and get your oil clearance spot on. Personally I either consider it a stock application and just hone them .002" and use the special bearings, or upgrade the customer to a real performance rod.
http://www.summitracing.com/parts/cle-cb1776a
This is used for what you are doing. I am doing the same thing. ARP rod bolts, so I will resize and use these bearings.
Great info though, thank you!
http://www.summitracing.com/oh/parts/cle-cb1776a108
Lot of different opinions on this deal. My first go around I had my rods resized to .002 overbore. Now that im buiding another engine and wanted to run a good quality bearing on a stock journal crank, I wasn't able to find anything except .010 under. I wasn't going to sacrifice using a normal clevite bearing this go around.
My local Tech school engine builder, which does a ton of LS stuff. Sold me a stock set of rods and said they have maybe 1 in 50 rods that go out of spec with ARP hardware. And never do resizing. They throw away rod and get another. or use aftermarket if HP goal is over 700.
So I currently have stock rods/ARP bolts/ ACL bearings. Still confirming my clearances as we speak. Hopefully i'll have solid numbers by Friday.
My suggestion is to install ARP hardware and check your rods with MICs, not plastic and go from there. 2cents
Any competent machinist will tell you that if you increase the clamp load on a bore you are going to distort it....most times in ways that cannot be seen with a two or even three point gauge...simply put, the rods turn into a square and need to be resized, that guy shouldn't even be teaching people how to change a spark plug.
Think of it like this, imagine that you have a set of brand new tires on your car but they werent balanced. Now driving around town say at 35-40 mph your probably not going to notice anything but when you get on the highway the car will start to shake like crazy. Now imagine a unbalanced stock engine. Your average person with a daily driver isnt going to notice it, now you decide that you want to double the horsepower, and take it up to 7,000 rpms if you dont take the time to balance it precisely then you might start having problems above 6,000 rpms. The main problem with rod failure IMO is because of balancing. The higher rpms cause a lot more vibration which causes the rod to fail in a unbalanced engine. You can have the best bolts in the world and they might still break. Also on a LS anything over 7,400 rpms should have performance rods, pistons and crankshaft. There are too many variables as to why a engine fails. As a performance engine builder for the last 20 years I can honestly say that if you dont get your numbers correct including balancing for the application you are using it for you will have a failure.
I totally couldnt agree more. Unless youre going over 700 hp (which on the street would be insane) on a LS engine then using the stock pistons and rods are more than enough. Your instructor is a very wise man! The engineers really did their homework for the LS. These engines are designed with a lot better machine work and equipment than the Gen. l. These arent the engines from the 60s and they can handle a lot more horsepower than most people think. The major key in a high reving engine is balancing. I wont get into my specifications in balancing but it must be done correctly with the whole rotating assembly. Even if you take it to a machine shop for balancing you should always double check their work. If you dont have the equipment to check then send it to a second machine shop to double check. I actually like to be present when they dynamically balance my crankshaft because it puts them on their toes and they focus more. This is the only part of the balancing that I cannot do because I dont have the equipment to balance the crankshaft.
