ticking at 1700 rpms
this sound started out only at higher rpms then once the lifter became more worn it turned into what you hear in this video...
Edit: you said you replaced the rockers and pushrods
well ok so then you can totally also do this simple test to find out if its a lifter or not
if your interested in doing this let me know and ill do a write up.. or we can chat on skype.. itd be much easier to chat on skype, i will say this in short, it involves removing one rocker and pushrod and injector at a time and replacing until the sound goes away, if sound does not go away, its not a lifter.. Edit: Also to check for rod knock, just remove one spark plug wire at a time until the noise goes away or is greatly affected, then you know which one if any
peace
