Help chirping noise!!
Old Mar 2, 2023 | 07:16 PM
Tommy42088's Avatar
Default Help chirping noise!!
So my truck recently starting chirping and I thought it was something simple like a belt or a tensioner well needless to say that's not the issue. Sounds like the sound is coming from the passenger head. Truck isn't running bad or anything but it's definitely chirping and I'm pretty positive it's coming from the passenger head. 5.3 gen 3 block, 243 heads, port polished milled btr stage 3 cam with dual springs and trunion upgrade. Truck has had all parts at least 1 year and been running solid with no internal issues until possibly this. Thanks
Old Mar 2, 2023 | 10:03 PM
9 times out of 10, the chirping is from a lifter that’s turned in it’s tray and is eating the lobe off the camshaft. Pull your oil filter and cut it open with a filter cutter or tin snips. That will tell the story every time.
Old Mar 3, 2023 | 02:16 PM
Tommy42088's Avatar
I just changed my oil a few days ago and my filter was good and I even filtered my oil and didn't see anything. I pulled the valve cover and everything looks good there too
Old Mar 3, 2023 | 02:32 PM
Tommy42088's Avatar
I would think it would pull a knock sensor code if it was a lifter. Wouldn't you think? I tried uploading a video and it won't upload for some reason
Old Mar 3, 2023 | 04:10 PM
Jimbo1367's Avatar
^^^^^what he said^^*^^^*
Old Mar 3, 2023 | 04:39 PM
Tommy42088's Avatar
so replace the lifters, trays and cam? Theres nothing in my oil, ive already checked it. I did that a few days ago. The basic ive already covered. Checking oil, checking filter, checking belts, removed belts. All the simple things ive done.
Old Mar 3, 2023 | 05:26 PM
Gene Cheeseman's Avatar
The oil flows from the sump to the pump to the filter.
You said you filtered the oil. As in what was drained out?
It's going to be in the filter. This is when you catch it very early. This was hardly making a noise, but it was a chirping tap. I have a video of it and it's worthless, can't hear it.
Old Mar 3, 2023 | 05:59 PM
Tommy42088's Avatar
as in the oil I drained oil I filtered it with a rag and cut the old filter open and I didn't see anything. I ordered ls7 lifters and all the gaskets and im pulling the heads now. Ill take pictures once i get them pulled. I didn't order the cam yet because I wasn't sure if it would be damaged or not
Old Mar 3, 2023 | 07:33 PM
Tommy42088's Avatar
Can I reuse head studs
Old Mar 3, 2023 | 07:51 PM
Tommy42088's Avatar
I forgot what head bolts to use for the 243 heads if I do have to change them
Old Mar 3, 2023 | 08:19 PM
If the lifters are chirping the cam is damaged.
I wouldn't have ordered parts until I found the problem.
I've stuffed and taped rags in the exhaust before to hear exhaust leaks. MLS gaskets can sound like a chirp, gets a lot louder with the exhaust plugged up.
Old Mar 4, 2023 | 12:06 AM
It's not head-related. The bolts used depend on the block, the older of which have deeper head bolt holes.
Whatever you are using in your presnt block are the ones used on any other head you put on it.
Old Mar 4, 2023 | 12:10 PM
Tommy42088's Avatar
I put a stethoscope on the head, the sound is definitely coming from the passenger head. I should have it broken down by today. Hopefully I see the problem
Old Mar 4, 2023 | 12:18 PM
Tommy42088's Avatar
I understand it's not head related but my question was do i need to use new bolts since im taking it apart
Old Mar 4, 2023 | 01:14 PM
grinder11's Avatar
GM bolts cannot be reused. You mentioned studs. If you have studs, they are usually reusable.
Old Mar 4, 2023 | 01:17 PM
grinder11's Avatar
BTW, I do hope you installed new trays with your LS7 lifters. Make that new GM trays, not Chinese junk trays.....
Old Mar 4, 2023 | 01:36 PM
Tommy42088's Avatar
I haven't installed anything yet but I ordered lifters, trays, head gaskets, intake manifold gaskets so far and I got it from summit. I told them what my setup was and they helped me choose the parts from there
Old Mar 4, 2023 | 01:37 PM
Tommy42088's Avatar
that's what I'm asking, I do not have studs. It's factory gm bolts. So i order the bolts or studs that match my block correct?
Old Mar 4, 2023 | 01:39 PM
That is correct.
100% truth there.
