Straub Bushing Trunion Kits?
Old May 13, 2016 | 10:16 AM
  #221
brobinson216's Avatar
Originally Posted by The Alchemist
Is it a case of the trunnion itself is not hardened properly?
I sent one to Element labs for chemical and physical makeup.
Should have results within the next week. This was on my on account.
Old May 13, 2016 | 11:42 AM
  #222
The Alchemist's Avatar
UNDER PRESSURE MOD
So I'm guessing the stock rockers with needle bearings had this same issue... or am I wrong?
Old May 13, 2016 | 11:48 AM
  #223
joecar's Avatar
A bushing style bearing can take much more load than a roller/needle style bearing... and they both require lubrication.
Old May 13, 2016 | 02:25 PM
  #224
joecar's Avatar
The OE rockers are a different arrangement... the needles/rollers do not run on the trunion, they run in between inner/outer hardened sleeve pair (i.e. inner sleeve is pressed on trunion, outer sleeve is pressed in rocker body)...
so if you're looking for trunion damage, it would show up on the running surfaces of the inner/outer sleeves, these are made from hardened steel stampings, so they will not show any wear.
Old May 13, 2016 | 02:26 PM
  #225
joecar's Avatar
I surmise that the Comp trunions are not heat treated properly, I will test this when I get home (see if a file cuts the running surface, if the heat treatment is correct then it should not).
Also note that the OE needle/rollers are bigger than those in the Comp kit (bigger radius roller spreads load out a bit more).
Old May 13, 2016 | 04:50 PM
  #226
Zmg00camaross's Avatar
I never liked the comp style trunion. Why I am still rocking the stockers. I liked the CME or something bronzed bushing upgraded ones but were to much money and mite as well go aftermarket. These look great and should be installing a set in my buddy's rockers this weekend.
Old May 14, 2016 | 08:22 AM
  #227
joyridin''s Avatar
There is a lot more to this than just the heat treating. I bought a set from Summit and the surface finish where the bearing rides was pathetic. We checked it on a Profilometer and in was around 20 Ra. It should be around 8-10 Ra. With that bad of a finish (it was not even ground), it will not take long for the rollers to pick up material and destroy the rollers, which looks like the issue with the pictures above.
I can have the material checked for hardness and run a metal analyzer on the material next week. It will tell you everything. My guess is it is something close to 4140 and about 50 Rc. They should be 52100 bearing steel and about 60 Rc, but that would double the price.
Old May 14, 2016 | 08:36 AM
  #228
Installed the Straub set lastnight, waited until this am to crank the Corvette.
Horrible squealing noise when it first fired off. The noise has now deminished. I will be changing oil and filter later today for safe sake.
As far as valve train noise goes, there's no noticeable difference.
Old May 14, 2016 | 09:19 AM
  #229
Redbull87's Avatar
I had a squealing when I first started mine also. And I had soaked it in oil prior,also cranked the engine over a few times to build oil pressure before having it fire up. The noise did go away after building some heat into the valvetrain. I plan on changing the oil after breaking in my clutch and going to a quality 10w30 and see if that helps. Valavetrain noise seems about the same otherwise imo...but then again my car is rather loud regardless.
Old May 14, 2016 | 12:15 PM
  #230
My fears confirmed......changed the oil and found micron particulates in the oil and filter. Not sure if the pictures will show in detail.
Change your oil after start up.
I allowed the bushings and trunions to soak in zinc additive overnight on Thursday, assembled on Friday afternoon. Once the assembly was completed I placed all rockers and bolts in a tub of mobil 1 oil until around 8:00pm last night and then installed.
This morning I cranked the car.
Pictures attached after ten minutes of run time.
This was my primary concern and why I asked the question initially.
Just wanted to add this oil pictured had less than 550 miles of use. Mobil 1 10w30 Gold Cap synthetic. So the color of the oil should show why I'm concerned. This is a 2006 Corvette with 22k miles.
Old May 14, 2016 | 12:22 PM
  #231
UNDER PRESSURE MOD
Ok, that's not good.... can someone please explain if this is typical, and what it is we are seeing here?
Old May 14, 2016 | 12:45 PM
  #232
Redbull87's Avatar
Yikes I should really go check my oil now,Ive had it running about 2 weeks. Better change oil asap!
Old May 14, 2016 | 12:48 PM
  #233
Redbull87's Avatar
Thats quite a color change in oil though which leads me to believe alot more is at play there. Judging from the oil on my dipstick its still perfect and no shinybits that i can see. But I think you just convinced me to doing a quick change anyways!
Old May 14, 2016 | 12:54 PM
  #234
My dipstick appeared clean as well.......however after further investigation.
Nothing else is going on here, it's a 20k mile garage queen with a cam, converter, intake, exhaust.
Matter of fact just for reference here are the rockers removed from the motor lastnight
Old May 14, 2016 | 02:19 PM
  #235
joecar's Avatar
Default Straub Bushing Trunion Kits?
I ran a file across the Comp trunion bearing surfaces, it hardly scratches at all, so the surface is hardened... I wonder how deep.
I agree with you, I look forward to your findings (my only test tool is a set of files).
Old May 14, 2016 | 02:44 PM
  #236
Steve Cox's Avatar
Just happen to have a ME for a son that is a automotive ME at NMSU. He is going to look over this thread, and asked me if anyone would be willing to donate a few faded examples to run through his lab.
Old May 14, 2016 | 02:59 PM
  #237
ME here. Like I stated earlier I sent 2 trunions from a low mile previous project to a well known lab for analysis. As far as RA finish of 20 goes on the bearing surface, one must remember RA shows average peaks and valley's.
I had .0006" - .00085" press between used rocker bores and bushing OD. Which is sufficient for this application.
These were measured on a microview cnc vision system, backed up with a master calibration set of disc micrometers.
Old May 14, 2016 | 03:25 PM
  #238
Originally Posted by Jontall
Are you saying that there is a problem with the Straub bushings too?
Jon
This is the oil that was drained from my engine this morning after installing the Straub bushing trunions. Ten minutes of runtime. The sun makes the oil appear worse than what it is. But if you can zoom in on the photos the small particles can be seen throughout the drained oil.
Old May 14, 2016 | 04:40 PM
  #239
Jontall's Avatar
Jon
It's full of what appears to be bronze particles... Are you going to disassemble one for inspection? Those particles might damage the oil pump and the bearings.
Old May 14, 2016 | 04:46 PM
  #240
Correct it sure is.
Not sure what to do at this point.......still pondering.
