Straub Bushing Trunion Kits?
Bronze shows varnish on the bottom 1/5 of the ring only, this is where it would take the most load. There is no scuffing, galling, or deposits anywhere. The varnish is just discoloration. Trunion looks like it did when new. Nothing out of the ordinary here. Took three apart, all looked the same.
If anything, some extra lube on the bottom side would help. The grooves are on the top/nonloaded side, which is good for gravity feed - but the bottom is where the load is. These don't snow ANY wear other then the varnish, which isn't wear, but what brass does when rubbed over time. Very happy with them.
Kurt
The damage above to me looks like the copper bushings were sunk to deep causing interference. I spent a lot of time getting the amount of play just right. If done correctly there is some clearance for lateral movement, but not enough that the outside of the bushings can contact the snap rings.
Lateral movement would be the clearance between the shaft and bushing, which can only be adjusted by machining of the bushing or trunion bearing surface OD.
If the bushing were set too deep that would create an inside interference, in turn never allowing the snap ring to contact.
Care to try again?
Making re think using these on my build. Also seems no trunion upgrade is fail proof
Care to try again?
Kurt
Kurt
