Straub Bushing Trunion Kits?
As far as the bushings being set too deep, that is not the case.
Root cause has been determined and will be released in a few days.
PR are comp 5/16 .080 wall
Kurt
Kurt
I do find humour in anyone seeking to find fault in a budget part when it fails, especially when they lay claim to enough "expertise" to quote very specific material specs, principles, and assembly tolerances. I know that if I had access to those resources I wouldn't be messing around with modified stock junk, and then get upset when it doesn't perform up to my expectations. But, that is just me.
I say this as I agree that it does not seem that the oiling design had to change to make the bolts work.
I've got a beater 4.8(236K miles and literally runs GREAT with 40PSI+ hot idle) truck now and a set each of the new bush, old bush, Comp roller, Harland Sharp roller and I am pulling a handful from each. I'll install these on the truck this weekend-ish and I'll watch them grow old with the truck and planned upgrades, each set rocking two cylinders.
