Straub Bushing Trunion Kits?
I'm glad to see that I'm not the only person on here that has to discuss things like this with their wife! I keep having to explain to my wife why I keep spending money and it doesn't look like there is any progress made on the build...
I think she's tired of stepping around the motor to get to her beach gear...
Take it how you would like, and I refuse to go into negative exchange with you.
In no way did manufacturing these trunions ever cross my mind, nor would it.
Your arrogant post proves volumes. In the end I'm a customer who bought a product and it failed.
Then you respond with: Your foolish for trying to help , and by helping you send another inferior product to replace the first?
As far as discrediting you or your product.......The above speaks for itself.
Best Regards
How to win friends and influence people; this is not how to do it, kids.
Keep your precious results Mr. B. Robinson - no one cares.
ZDDP... I put that **** on everything!
stock:
pro: good wear, larger needles.
con: ability to scatter needles.
comp:
pro: retained bearings.
con: trunion surfaces wear quickly sheding steel particles (materials problem?); smaller needles (less load capacity).
bushing:
pro: no needles; higher load capacity; if it wears it sheds bronze/brass
particles (soft); will make noise when sufficiently worn (rather than failing).
con: sensitive to receiving lube via PR/rocker.
any other points...?
Kurt
stock:
comp:
bushing:
stock:
comp:
bushing:
May she R.I.P.
Kurt
Thanks
Chris
Kurt
Kurt
Do you remember if this was in a straight or offset rocker?
Thanks
Kurt
Kurt
Probably the same reason that most haven't seen that I posted that all sets I've assembled ended up with some bronze shavings around the edges of the bushings that I blow out with air before completing the assembly. I think this is normal consequence of pressing a soft metal(bronze bushing) into a hard metal(steel rocker) and not a flaw but an assembly consideration.
Now if they are greased with something thick, the shavings might be hard to get out.
