Straub Bushing Trunion Kits?
I can not simply drop the bolts through the trunion and hand thread them in. There is no clearance and the bolt gets stuck about half way through. It will go if I tap it through with my socket wrench a few times and or thread it in with a wrench but this doesn't seem normal to have such resistance when stock just dropped right through.
Is this normal?
or maybe it doesn't matter at all if its forced through because once torqued the trunion isn't going anywhere and the rocker is going to be doing all the moving.
but the lack of clearance leads me to believe this will affect my final torque as the bolt is fighting the trunion....
can I just buy the aftermarket straub bolts and be good or maybe just sand my stock ones a few thousandths to make some clearance...
i'm a little annoyed as the reason I bought these pre assembled was for ease of install and the promise they just bolted right on...
Do not use them.
I will post pics of mine when I do the swap in 1-2 weeks.
Just another snag in the project lol. Thanks to all that have suggested solutions and or pmed with helpful ideas.
I'm sure it will get sorted out.
I'm most definitely not against buying some rocker bolts if needed I just wanna know what and where to get it. Which I'm working on
Is this normal?
So I'll try the after market set which I'm sure will be fine.
Anyone else with a gto is probably used to this as it would seem everything on this car is different in some way then the next gto down the street lol.
I'm not the kinda guy who wants others to pay for my issues. As this is no doubt a quality control issue with my gm bolts I will be paying for the required after market bolts.
Those of you in the future I would probably just advise buying the kits with bolts for peace of mind.
It might be the gm supplier to the Australians are different since my gto was obviously built over seas. I have no idea but food for thought. The straub bolts are .313 so u have nothing to guess.
A plus to everyone who helped me figure out what's going on!
