Straub Bushing Trunion Kits?
Old 03-11-2018, 02:12 PM
  #861
RB04Av's Avatar
ws6store has Straub, Texas Speed has CHE.
Old 03-11-2018, 02:27 PM
  #862
CR500's Avatar
Me too with CHE. VERY easy to install, no tools needed, fantastic machining tolerance. Several track days (HPDE) and just as quiet as when first installed. No wear measurements but nothing I can see or feel. Got mine direct from CHE.
Originally Posted by qweedqwag
I installed a CHE kit. Only has about 300 miles on it, no issues and no signs of bronze material in the oil. Super easy to install with this
Old 03-14-2018, 09:09 PM
  #863
Mike Morris's Avatar
My Comps after 3k were falling apart. Have CHE now...
Old 03-17-2018, 08:49 AM
  #864
NEstyle's Avatar
Manton has a kit now. I wish these were out when I bought my Straubs (or whoever actually makes them), which I'm not thrilled with.
http://rollerrockerarms.com/ls-bille...-trunnion-kit/
Old 03-17-2018, 01:33 PM
  #865
qweedqwag's Avatar
Default Che
I like the che as it has oil grooves to help with oiling. 700 miles no issues.
Old 03-17-2018, 07:39 PM
  #866
Good to here. I went with CHE
Old 03-21-2018, 02:15 AM
  #867
Jontall's Avatar
Super expensive....
Old 03-21-2018, 09:55 AM
  #868
Received 3,033 Likes on 2,361 Posts
What don't you like about the Straub kit?
Old 03-21-2018, 11:11 AM
  #869
NEstyle's Avatar
A major design flaw, in my opinion, is how the inside edge of the bushings rub on the wider portion of the shaft if side loaded. To test this, assemble a rocker and rotate it back and forth on the shaft. You'll be left with millions of little pieces of brass because the shaft is not smooth where it touches the bushing and just grinds into it. Not good.
The brass bushings in my kit were badly oxidized and had to be cleaned really well. I could not see the oxidation on the bushings, but I could feel it when rotating a bushing on a dry shaft prior to assembly. Lots of green oxidation came off the bushings during cleaning. The rags turned green! After cleaning off the oxidation, they felt smoother.
Surface rust on the shafts. Required polishing to remove.
Poorly machined bushing IDs. About 90% of my bushings' IDs were stepped and not smooth. The fact that some looked perfect and others looked stepped was very unsettling. I sent that set back and was provided with another set that was exactly the same. I was assured that they were all "within spec". Scary. I simply don't understand why they all don't look the same. That points to QA/QC and machining issues.
Barely any bearing area, especially on the latest design with the oil groove.
Old 03-22-2018, 09:01 AM
  #870
chrysler kid's Avatar
Originally Posted by chrysler kid
My "shop press". $30 @ autozone
Over 2k miles and the CHE kit is still holding up great. Engine runs smooth as ever, and my 80k mile futral cam (notoriously noisy) has been tick free the entire time
Old 03-22-2018, 03:57 PM
  #871
Awesome
Old 03-22-2018, 08:27 PM
  #872
jetech's Avatar
Straub Trunnions here!I think they are quality pieces
Old 03-14-2019, 01:37 PM
  #873
Old Geezer's Avatar
Older thread, new questions.
I ordered a Smith Bro's trunnion kit. The bushings are loose in the rockers. Rockers are @111K miles, from an L33/Suburban engine, that didn't appear to ever been apart.
Sent them back, and ordered a Straub kit....Exact same kit, even down to the location they were shipped from. [Piney Flat, Tn.]
New kit is loose, too. [Looks identical to the pic in post # 872.]
The previous kit from Straub, fit exactly as it should.
The questions: Is it common to find stock rockers w/ over sized bores? [The original needle brgs were tight, in these rockers.]
Is the CHE kit full floating?
Old 03-14-2019, 03:04 PM
  #874
The CHE kit IS full-floating
Old 03-14-2019, 05:14 PM
  #875
Old Geezer's Avatar
Thanks!
Old 03-14-2019, 05:41 PM
  #876
Originally Posted by Old Geezer
Thanks!
You bet!
Old 03-14-2019, 05:46 PM
  #877
qweedqwag's Avatar
I'm running the CHE kit, got about 2k on them with no issues.
Old 03-15-2019, 08:22 AM
  #878
Old Geezer's Avatar
Going to return the Straub, and get a set of Che....
Thanks all, for the responses.
Old 04-15-2019, 08:11 PM
  #879
Bazman's Avatar
Manton makes some good stuff, if their QC is good on those, they should be a nice set
Old 11-04-2020, 04:07 PM
  #880
Ozz1967's Avatar
I have 6000 miles on my Straub kit since install and I don't see any issues with them so far.
Quick Reply: Straub Bushing Trunion Kits?
