Torquer V2 w/243 Heads Tips
Edit: I ended up buying the heads and cam so now I'm looking for tips on what to do while I have everything apart.
I'm running FMS F14 cam 232"/234" .598"/.598" 112LSA with hand ported 799s. My car is in same neighborhood probably little more though.
You would be in the 400s for sure with proper tuning.
Lifters stock will work but for how long is up in the air. With the heads off you might as well upgrade them.
Change lifters
New oil pump
Timing chain
arp crank bolt. the stock one is a one and done bolt so you need a new one anyway
maybe pulley if you can swing it too
