Why did I come up short?? 487hp is not 500+
Car made 487 yesterday and I was really aiming for 500 - any ideas on how to get there and where I went wrong?? (NA no spray, that's later lol)
Callaway intake
100mm MAF
NW 102
Fast 102 - port matched to the heads
56# injectors
OE rotating assy
OE compression
PRC stage 2.5 heads
TR55's
288/291 .605/.610 111LSA cam
Johnson short travels @ .025" to .030" preload
Yella Terra Roller rockers
3/8" pushrods
1-3/4" LT's
high flow catted X
Borla stingers
Under drive pulley
graph was basically done at 6900-7000
Can anyone help me with why I didnt get pushed over the top?
Engine was at 25* total timing too
At basically sealevel on a 50* day in a shop/shaded dyno bay
Callaway intake
100mm MAF
NW 102
56# injectors
OE rotating assy
OE compression
PRC stage 2.5 heads
TR55's
3/8" pushrods
1-3/4" LT's
high flow catted X
Borla stingers
Under drive pulley
you could try two things: slightly higher compression pistons might help some, or you could take it to another dyno. Most dynos are different and will spit out different numbers. You could always shop around until you find the graph you want. What really matters is how the car feels and performs on the street/strip
Mill your heads, replace the SS valves that come PRC 2.5's with some turned down LS3 valves and you'll be there IMO. Also, there no mention of what clutch you're running. Lighter clutch and flywheel will make a difference in what power you push through the tires.
1 7/8 inch longtubes. You'd be surprised what an 1/8" can do and bumping up the compression. Only thing is you could've had that make with some flat tops and a little more rigid bottom end to handle it a little better. Along with a colder plug and a bump in timing you got it. Nice numbers though.
Wonder if the roller rockers hurt it too?
Clutch is a 18lb flywheel and the clutch is a 9" unit. Overall clutch/pressure plate setup weighs the same as stock but the small diameter helps the moment of inertia by about 20%, then add the lighter FW.
I'm going to do a forged rotating assy in a bit (once I get it to run right lol) and I will bump compression to about 11.5 or so and I can turn it to 7200+
I was worried that 1-7/8 might make a diff... Wonder if I can just get the LTs and have them bolt upto my current X-pipe...?
Lightening the value train on the top side is always a good thing... More stability, easier on parts, and allows you to spin it higher, along with longer peak torque carry. All these things equate to power. Yes, the yellow Terra's aren't doing you any favors as the stock rockers are about the lightest most durable rocker still to this day on the market. Add a trunnion kit to the stickers and you're set.
Not sure who's spending less and NA getting 500rw out of an LS1. Truthfully, this is the highest number I've seen with PRC 2.5's! They aren't the best head out for the 346 or 364. Now, bang for the buck, the PRC as cast 225's with light valves, or the TFS as cast 220's put down the power while still being cost effective. I by no means am knocking PRC's work on stock heads... As I'm running stock LS7's ported by PRC on their 265 program and they flat out perform!
BUT I understand what you're getting at, I focused on a number in my last build and ruined it. This one was 500hp AND drivable (in the opposite order tho)
Cam is 236/241 @ .050 IIRC
Forged bottom end is coming in fall so I will raise compression then on it. Was trying hard to hit it with OE short block and just ported heads by watching the details....
Don't get me wrong I'm definitely stoked about it for that reason - just curious as to what I could e done better. I didn't just toss parts together to get to this, but I did come up short of the goal. I figured I would ask if anyone knows what I could've done better... Sounds like rockers and headers are the consensus
Very impressive numbers none the less. Do you have a graph you could post?
