11/32 pushrods neccessary?
Idea is to keep the valve springs, retainers and valves light while keeping the pushrods as strong and big as possible.
I was mainly doing it for the restricted oil on the push rods while I had the rockers apart.
Now I will say I went from 4l60e,3.73 10 bolt, aluminum drive shaft to th400, 3.70 9", steel driveshaft, mild steel roll cage, and the car picked up on the top end by 3 mph and about .2.
Now IF I ever build a screamer road race deal which would have the capability to (even if the power dropped off long before this) spin to 8500 or so with a crazy cam, and stupid high pressure springs, YES, it will have the most tree trunk like pushrods I can fit into the heads without weakening them, and the top of the line, shaft mounted rockers as well.
But when they can be acquired for virtually the same price as what most companies sell the 5/16" pushrods for, it certainly won't hurt to step up the diameter. Even at 5900 RPM, you'll be adding stability.
(I just installed some 7.400 stock length trick Flows, and stock rockers hoping that was the cause of my LOUD valvetrain 'clacking', sadly it is still there, so it must be the damned lifters, and I neither have the tools/facilities/skills to pull the heads, nor the $2500.00+ most shops want for the job.
