Rod question
Ok sounds good thanks, but I'm having trouble deciding on a rod. I want to go with Callie's but I can't find a 6.100 rod with a .945 pin. I can only find Eagles. I'm going with a pretty high powered build (1000hp+) and I want to know what rods will hold up
Moderator
Yeah, just be sure to have a machinist pin fit the rods and pistons. What they will do is measure the pin bore diameters in the rods and pistons and the diameter of the pin itself and hone the bores as needed to get adequate clearance. So if your pistons came with a .945" bore and the rods are .943", then they can hone the rods .002" to .945", or whatever diameter is needed to get the needed clearance.
Moderator
I've seen them used in 1k whp combos, but they wouldn't be my first choice for something like that. You kind of shot yourself in the foot going with a .945" pin piston; most of the aftermarket stuff is designed around a .927" pin. I'd rather have a Callies Ultra rod for what you want to do, but again, they design all of their Ultra LS rods for a .927" pin.
