Are these cylinder walls glazed?
I purchased a junkyard LQ9, and just pulled the pan to check the internals. I'm not experienced with this at all but I know the cylinder walls should show a crosshatch pattern. They do below the piston ring contact area but above that, only slightly. Can I get your opinions on whether the cylinders should be honed? If so I'll probably use a dingleberry hone.
Plans for the engine are to not remove the heads at this time -- to get the wiring and programming, sensors etc. straight so I can drive it and then figure out what to do with it; it'll be NA and I'm cheap so I'll probably stick with stock heads too.
Once an engine has even a few miles on it, the cylinder area that gets ring contact is not going to look like the undisturbed honed area. In my book for a budget build, if you can see a little cross hatch and you trust the history of the engine, go for it. If the history is sketchy and you want confidence, pull the heads and have a better look. If on a tight budget, you can use cheaper graphite gaskets and standard replacement bolts. There's a lot of cylinder you can't see from the bottom.
Any info on mileage or running condition before purchase? Compression test? Based on the very little bit I can see, I would run that engine if the rest looked similar.
I really don't want to have to scrape and clean a graphite gasket more than once so if I pull the heads it's going to have some consequences on my wallet For example, if I pull them I'll probably want to get MLS gaskets. Then if I'm doing that, I might just figure why not get a whole gasket set to redo the entire engine. Of course with the heads off I might as well drop in some ebay studs and that's another $90... and what if I decide I need to have the heads or block machined!
I guess what I'm saying is that if I can run the engine as it is now, I'd rather defer the cost until later -- not only because I'm cheap but also because I don't really know enough about the LS platform yet to not throw money away on suboptimal stuff only to have to redo it later. To be honest, I don't know my end goals and probably won't until I get the engine in my truck and get a seat-of-the-pants feel for how much more power I want.
On the other hand, given that the engine is not super clean, and I don't trust it's actual history I *am* tempted to pull the heads to inspect and clean the carbon off, maybe lap the valves.
I do think I'll run it though
Plenty of technicians across the country run 1 quart of ATF through a car with noisy lifters. Drive it gently for a short time and drain the oil when it's hot.
Would I do it in anything I cared about? Absolutely not. You run the chance of clogging the pickup screen too.
I should state this motor has a 6 month warranty so if it starts to knock, I'm not out any money.
I have ran about 50% ATF in the oil in a demo derby car that had a damaged oil cooler though lol.
I have a tub of ATF brake cleaner mixture for cleaning small components (soaking lifters for a few days), it works wonders, disolves crusty deposits, lubricates, protects against rust.
The compression is within tolerance. Its good for another 100 thousand. That's exactly what the walls are supposed to look like too. I wouldn't try and clean it. It looks just like my ls1 (115,000) after I pulled it for the new ls2. It ran great! Got to find a jeep for that thing somewhere.
