Comp LSR 227-235
I was curious to see what kind of numbers I should expect with this cam. My mods are: 799 heads with a performance valve job, 3.905" bore, 10.5:1 compression, 1-3/4 long tubes, stock LS1 intake manifold, T56 trans with 3.70 gears.
I'm hoping to make near 400 but I'm sure the stock intake is hurting me a little. May upgrade to a FAST intake and TB.
I've attached a video of this cam right after starting the new motor. It sounds really good and chops hard. This is on a start up tune only and with open headers.
https://youtu.be/KGc_3NdyLdo
That's the link for my video, not sure how to make it work on here though.
https://ls1tech.com/forums/dynamomet...0hp-400tq.html
https://ls1tech.com/forums/dynamomet...428-377-a.html
https://ls1tech.com/forums/dynamomet...stg-2-cam.html
Here are some that are close to your setup. On the last one checkout post 8 by Matt@tick
