Bad valve seals causing loss of power and low #s?
I wouldn't think so either. As he said, they just stop oil from getting past the guides. It could be bad enough as to foul a spark plug while parked and then it burns the oil onto the plug which could cause a little loss of spark intensity. But I don't think you would notice it. If you are asking because you have a fouled plug or 2, I would bet you have bad oil ring or rings, or cylinder wall issue allowing oil into the top of the cylinder and that can be enough oil to foul a plug and lose power.
Yea it smoked quite a bit we assumed it was the coating from the headers as the set up is new but we are leaning towards a bad seal cus thr oil loss is starting to show up
Ls6
stock intake
stock heads
Kooks lts no cats straight pipe all the way back
Torquer v4 112lsa 231/234 .629 .615
Car dynoed at 387 and 369
I get that the stock intake is choking but i honestky expected more sonewhere in the 400-415 range
