241 Head Milling Question
Try this Comoression Ratio Calculator.
I'm not sure how you're getting 11.17:1. I put in the info for a stock 241 head and a GM LS1 head gasket and got 9.84:1.
Bore: 3.780"
Stroke: 3.622"
Head Chamber: 66cc
Valve Relief: 0cc
Head Gasket Thickness: .052"
Head Gasket Bore: 3.910"
Deck Height: -.005"
**The Compression Ratio is: 9.84**
Again, I plug those numbers in and I only get 10.7:1. Still a long way away from 12:1, and without valve reliefs, milling 60cc is going to make PTV tight with a decent cam.
