Burning lots of oil, good compression, checked pvc and new valve seals
Old 03-27-2016, 09:38 PM
LSx '85 C10's Avatar
Default Burning lots of oil, good compression, checked pvc and new valve seals
So the previous oil change was about 4 months ago and i did valve seals and new springs with it i know i installed the seals wrong so this oil change i went ahead and did new ones, since then (about 2 weeks and 800 miles ive burned througha quart of oil, i checked the inside of the intake and it has very little oil residue also pulled the intake and didnt find any oil on top of the valves, i did a compression test and had numbers between 160-175psi any clue here? i wanna say valve guides but i just dont know where to go from here
Old 03-27-2016, 11:12 PM
truckdoug's Avatar
that intake valve doesn't look too gummy, what do the backs of the exhaust valves look like? my DD has streaks down the exhaust valve stems where they leak, lol
you running a catch can? that'll keep some of the oil out of the intake at least.
Old 03-27-2016, 11:17 PM
I have an ls6 valley pan with no catch can I can only see the oil coming out the exhaust at WOT i will check the exhaust valve tomorrow
Old 03-28-2016, 01:26 PM
pulled the passengers side header today and this is what i found, they look fine to me except the first one looks kinda wet at the top. is that normal?
Old 03-28-2016, 07:53 PM
anyone have an idea?
Old 03-29-2016, 07:47 AM
truckdoug's Avatar
that doesn't look too bad as far as oil coming down the valve goes, but you have some oil coming into the combustion chamber from somewhere. stock shortblock?
i'd look into a catch can for sure. I did a super cheap ebay set up and it works great.
Old 03-29-2016, 12:33 PM
Yep stock lm7 short block I'll pick up a catch can in a couple days and try it out,
Old 03-29-2016, 04:18 PM
Taxman20's Avatar
First question I have is what do the spark plugs look like? This is he first thing you want to check. That might tell you which cylinder is the culprit and also you can normally tell by the oil on the plug if its getting past the guide seal or coming up past the rings. With only a qt per 800 miles, you might not see it with the naked eye. But with a magnifying glass and bright light you can usually see what each plug is seeing.
There are many sources for plug reading but this one is pretty simple.
http://www.4secondsflat.com/Spark_plug_reading.html
And lots of pictures,
http://www.verrill.com/moto/sellingg...colorchart.htm
Old 03-29-2016, 07:51 PM
Moderator
Darth_V8r's Avatar
Received 1,838 Likes on 1,146 Posts
Did you have any port work done to your heads? If so, was thread sealer used on the rocker bolts?
Sometimes port work exposes the rocker bosses and oil leaks past the rocker bolts on ported heads. Typically see it worst on the intake side
If heads are not ported, disregard.
Old 03-29-2016, 08:58 PM
The plugs are white but about 4-5 of them have oil on the threads, as far as heads go they are stock 706 head with trunnion upgrade and prc .660 valve springs with titanium retainers, I burned 4.5 quarts last oil change without realizing until my oil pressure started bouncing around I added a bunch at the gas station.
Old 03-30-2016, 05:48 PM
oil on threads this is cylinder #3
Old 03-30-2016, 06:19 PM
senicalj4579's Avatar
+ 1 on the heads if they are ported. Mine are and I have oil on my plugs too. Im going to take the rockers off, clean off bolts, clean holes, and re-apply Teflon paste.
Oil consumption got worse with heads+cam in my car. Its pretty normal for 99-01 ls1s to consume a lot more oil.
Old 03-30-2016, 06:27 PM
just stock heads with a cam ls2 intake and headers , nothing too fancy
Old 04-01-2016, 12:13 PM
anyone else? should i try a catch can and go from there?
Old 04-03-2016, 05:05 PM
ttt for more info
Old 04-03-2016, 05:11 PM
truckdoug's Avatar
did you get a catch can?
Old 04-03-2016, 07:22 PM
is there anything else it could be, I'm trying to just make sure its going to fix it before i spend the money on the catch can
Old 04-05-2016, 07:34 PM
So i got my catch can in just need to get some tungsten, gas and filler rod so i can weld the bungs on the valve covers. does it matter where i weld them on? i know the rear of the drivers side cover but on the passengers side i was just gonna weld it under the coil pack so i can still fit the stock coil bracket
Old 04-05-2016, 10:43 PM
joecar's Avatar
Does the bottom of the inside of your intake manifold have a pool of oil on it (I can't tell from looking at the pic on my phone)...?
Old 04-05-2016, 10:46 PM
its not a pool more of a mist on everything i do have the ls6 valley pan.
Quick Reply: Burning lots of oil, good compression, checked pvc and new valve seals
