Cleaning oil/antifreeze sludge.
So.... now im back in the garage with heads off, they are back from the macine shop, although, i had them replace all of the valve stem seals (remember i have dual springs so they are the old school type, not the top hat design) but when i got the heads back i noticed one of the seals is already unseated from the guide and sitting right under the valve spring retainer?! WTH right?
So first Question, Do you think i should just compress and remove the springs on the one valve and reseat that one seal, or take it back to the machine shop and have them look at it? maybe my guides are too worn or my valves are?
Second question what is the best method of cleaning out all that thick chocolate milkshake aintfreeze/oil sludge out of my block?!? KEEP IN MIND my motor is still in the truck and im not able to pull it at this time. (truck is in a friends garage with limited time and space. And no cherry picker or stand.
Any advice appreciated thanks..
Thanks gagliano that is what i was planning just wanted to see if anyone new any better ways or products to use... But why do you suggest i change out my lifters? They were installed with my rods rockers springs and cam not more than 12k miles ago. If i Change lifters i might as well change rods too... right?
If you can take one of you long bolts and grind 3 or 4 grooves in the threads long way to make your own thread chaser/cleaner and run that bolt in and out of every hole and blow out thoroughly again
Use new head bolts each time you pull the heads unless you have arp or something equivalent
Are clean and dry. The only thin is the oil pan. I don't want to pull it but I am afraid if I don't then I will screw my self. And again once I'm done I don't want to have to tear the motor down again until I'm ready to rebuild it and no its not a hi milage motor at all its a crate lm7 with a bigger cane cam hard rods roller rockers trq convrtr etc. It only has 12k mi on it or so. It had a valve stem/ guide seal fail and when I put the head on the 1st time I had some antifreeze in the threads (rookie move) and this milkshake disaster was born. But I'll keep at it thank you again
Okay so you didn't say anything at the end of your post but you did at the beginning. Didn't know you knew already what a good way is to clean them.
So did you already know about using an old bolt so you don't have to buy a tool to clean the threads?
If you want to clean out the motor I would put a drain pan under the oil pan with the plug removed and pour cheap engine oil through the block. Flush it out with oil instead of fuel or chemicals. That way the only thing in there is oil.
Run the motor for 20-30 minutes at idle and change the oil again. Putting transmission fluid and diesel and all that **** in the motor is asking for trouble. The gaskets aren't made to work with trans fluid or fuel, they are made to work with motor oil, putting anything else in their can cause the gaskets to go to ****. Besides you don't need the help of other oils and chemicals to flush out water and oil. If you were trying to flush out old caked up oil/contaminants you could add flush agents or what these other guys mentioned but it's still a bad idea. Btw i've been a tech for 18 years, I know these things from experience and watching people mess up things.
I did get everything cleaned up fairly well (using ATF and than shading it with motor oil) I wouldn't ever run a motor with that **** in though. Sketchy. I got the heads back on and the yella terra roller rockers and **** back in as well. Just gonna continue to resemble the motor per Chilton manual and then do 3 or 5 oil changes until I trust it. Also pulled the water pump and everything is good their. No oil what so ever. So I replaced the gaskets cleaned up mating services and put it back on. Thermo was good as well. I'm not saying. Don't trust you. Or that you have lack of experience. Because if 18 years is how long you've been in the business that means you've been doing it since I was a little lad. Respect. Just doing what I hear 90% of forums suggest and hoping for the best. But thank you for your knowledge sor
Hope that transmission fluid doesn't end up causing you problems, a lot of people will tell you to use ATF but either don't know or forget to mention the harmful things it will do.
Oh, I forgot something else from experience, when water gets in oil it can ruin the bearings and possibly the rings too. Water isn't a good lubricant for engines.
Ya no **** water isn't good for engines.... look ***** or whatever your name is why don't you get down off the 10 story tall horse your riding? No one in this thread needs your 18 years of 'I'm right you wrong. I'm smart your dumb' attitude. I didn't feel like I was being disrespectful towards you what so ever. I never said you couldnt read. I didn't because 1. I'm not an *** hole and assume ridiculous things about people. And 2. How in the hell else would we still be having this pointless conversation if you couldn't read.
And 18 years or not your still the first person ever to advise against ATF.... so therefore I care less about what your oh so great "advise "you keep trying to shove down people's throats.
Here are two examples I found using a very quick search that say there could be negative effects to using transmission fluid as a flush agent.
http://www.bobistheoilguy.com/forums...&Number=560116
https://au.answers.yahoo.com/questio...7214451AAyDZJ0
Hmmm, some AT fluids have short lived additives that soften and slightly swell
seals. This is a desireable feature when replacing the ATF in an older
vehicle. This is a major component of most AT "conditioner" additives too. It
would tend to confirm you suspicion of a valve stem seal problem.
George Bonser
gr...@cris.com
So it's out there that people say this about ATF in motor oil. Do as you wish it's your motor. I would highly recommend using a flush agent that is made to be in the engine over ATF.
I've also had a handful of cars come in over the years where someone put engine oil in the brake reservoir and it annihilated the system, you could always tell what they had done the second you removed the reservoir cap, the cap seal would be 2-3 times the original size. So i'm really against putting fluids in places they don't belong.
